cbwelden Posted January 21, 2018 Posted January 21, 2018 (edited) Selling my '95 E36 M3- no time to race. This car is fully set up and ready for the track. It has a freshly rebuilt S52 engine- one race weekend on it. It was rebuilt with ARP headstuds, etc (Rebuild by Texas Track Works) The car is fast and can easily run front of pack. This car has always been professionally maintained (SoulSpeed Performance-Austin). I have folders of receipts going back to the original build (previous owner). - Fresh S52- one weekend - M50 intake manifold - Hard wired transponder- no subscription needed - TC Kline dbl adjustable suspension w/ TCKline camber plates and H&R race springs (750# / 900#) - TC Kline rear aluminum lower control arms - All frame/unibody mounting points reinforced with Turner Reinforcement kit (front engine mounts frame areas, sway bar attachment points, rear trailing arm points - UUC multi adjustable sway bars – front and rear - All bushings/connection points replaced w/ race parts BRAKES/WHEELS & TIRES: - AP Racing BBK w/ Ferodo pads - Rear – Std BMW OE calipers in good cond. with NEW Perf. Friction race pads. New rotors in box- spare. - SS brake lines throughout - BimmerWorld carbon fiber backing plates / brake cooling ducts -2 sets >> 17"x 9" SSR Comp H's INTERIOR: -Complete Bimmerworld Fire system (3pts on driver >> 2 to eng. compartment) -COBRA Evolution Kevlar seat with side head protection (good for up to 36”/38” waist) -Seat back additional restraint bolster mounted to cage (as seat is now over 5 years old) -Schroth 'Profi II' - 6pt belts -Multipanel race rearview mirror -SPARCO suede steering wheel with easy access radio buttons -Quick release steering wheel hub -IO-Port Camera mount -Radio box and wiring for in-car radio AERO/ Body: -New flush mount hood latches – professionally installed -Bimmerworld rear wing -Bimmerworld Max Velocity front splitter with stand-offs (also have identical spare) New in the last year: - AP Racing BBK w/ Ferodo pads - Dr. Vanos rebuild - Coolant reservoir and cap - Thermostat - New plugs - New Fluids (oil, diff and trans)- Brand new- zero hours - Rear CV Joint replaced - Solid rear bushings - New fan clutch - New side window net - New radiator expansion tank and cap - Idle air control valve - CSF oversized radiator - New euro 3.5" MAF - New Bimmerworld Max Velocity Evo II track splitter w/ standoff mounting kit - New water temp and oil pressure gauges - New VAC seat sliders (not installed) - Roll cage mod to satisfy NASA requirements Have spares- rear rotors, brake pads, front splitter, box of other parts. This car is ready to go and you get the peace of mind of having a fresh engine. It is a race car so has the standard scratches, small dents, etc. Car is currently set up for NASA GTS2 but can easily run other classes with other organizations. Weight is roughly 2,700# with ¼ tank gas. It has the max restrictor plate to get it down to roughly 200hp. I believe the HP was around 270 with no restrictor. Call or email with questions. Have more pics available- I can't figure out how to post them. cbwell at gmail Asking $25,500 ** link to pictures. Email me if you have issues. https://drive.google.com/open?id=16oyDtNz3x-eClUTfZ8AmvdxS9fdejJMY Edited January 26, 2018 by Guest Quote
DMCNCAL Posted January 22, 2018 Posted January 22, 2018 clint, Cannot access the photos, can you send to me direct. DMCNCAL at gmail Thanks Quote
cbwelden Posted January 24, 2018 Author Posted January 24, 2018 (edited) Sorry, not sure how I missed that detail. Asking 25,500. Edited January 24, 2018 by Guest Quote
