Springs Eibach, Hyperco, KWV different sizes
Doing a garage clean up and have a bunch of springs to get rid of, please see the list below and let me know which ones you want. $50 per pair of springs plus shipping. I'm located in Salt Lake City. If only 1 is listed, it'll be $25. Feel free to reach out if you have any questions. Some of them are new, but assume they are used. PM, call or text (435) 671-0882
Brand Free length Inner Diameter Springrate Part Number Color Quantity Other
Eibach 170 cm 6.0 cm 170 nm Red 2
Eibach 2.25 in 2.5 in 250 lbs Gray 2
Eibach 5 in 2.25 in 600 lbs 215762 Red 4
Eibach 5 in 2.25 in 1100 lbs Red 2
Eibach 5 in 2.25 in 1150 lbs Red 2 In Box
Eibach 5 in 2.00 in 1600 lbs Red 2 In Box
Eibach 5 in 2.25 in 750 lbs Red 2 In Box
Eibach 5 in 2.25 in 900 lbs Red 2 In Box
Eibach 5 in 2.00 in 1700 lbs Red 2 In Box
Eibach 5 in 2.00 in 1500 lbs Red 2 In Box
Eibach 5 in 2.00 in 1400 lbs Red 2 In Box
Eibach 6 in 2.25 in 500 lbs 241425 Red 2
Eibach 6 in 2.25 in 550 lbs 340940 Red 2
Eibach 6 in 2.25 in 600 lbs 239428 Red 2
Eibach 6 in 2.5 in 1450 lbs Red 2
Eibach 6 in 2.25 in 550 lbs Red 2 In Box
Eibach 7 in 2.25 in 300 lbs 25/96 Red 2
Eibach 8 in 2.25 in 350 lbs Red 2
Hyperco 5 in 2.25 in 1900 lbs Blue 2
Hyperco 7 in 2.25 in 550 lbs N/A Blue 1
Hyperco 7 in 2.25 in 525 lbs N/A Blue 2
Hyperco 7 in 2.25 in 400 lbs N/A Blue 2
KWV 100 mm 6.0 cm 80 nm 601 28 028 Yellow 4
KWV 140 mm 6.0 CM 150 NM MTH333531 Yellow 2 Rear CS
KWV 140 mm 6.0 CM 200 NM 981.343.531.8a Yellow 4 Front
KWV 140 mm 6.0 CM 140 NM MTH343531 Yellow 2 Front CS
KWV 140 mm 6.0 CM 220 NM 981.333.531.8a Yellow 2 Rear
Porsche 144 mm 6.0 CM 180 NM N/A Red 4 Cayman GT4 KMR
Porsche 147 mm 6.0 CM 160 NM N/A Gray 4 Cayman GT4 KMR
  • 1 month later...
  • 3 weeks later...
