NASA ST2 240Z
240ZGT
NASA ROLL CAGE # 011546
"Reduced Price!"
"Clean Title in Hand"
Near: Baton Rouge La.
Description
240Z NASA ST2 Race Car (011546) The car has a freshened engine with only three (3) race weekends on it.
Class Data
• Class: NASA ST2
• Weight: 2675 W/245 # DRIVER/20#Ballast
• Track: NOLA Motorsport Park with NASA/ Circuit Grand Bayou @ NPR with GCRS
Engine
• Manufacturer: Chevy
• Type: LS1 V-8
• Dyno: Dynojet, chassis dyno
• Displacement: 346CI
• Horsepower: 317 Rwhp
• Torque: 346 Rwtq
• Rev Limiter: Set @ 6400/ Shifted at 6000
• Balancer: SLP/ With Underdrive pulley
• Camshaft: GM LS6
• Timing set: SLP
• Valves: Stock Ls1
• Valve Train: Stock Roller
• Valve Springs Comp Cam Hi Po .600” Travel
Fuel System
• Fuel Cell
• Capacity: 15
• Fuel Pump: MSD LS1
• Sump: Custom Internal
• Filter: Serviceable prescreen & after pump Corvette inline filter
• Fuel Type: 93 Octane Pump
Oil/Cooling System
• Radiator: Tru-Kool Racing Aluminum
• Oil Cooler: Yes
• Oil Pressure Control: Corvette LS1 Batwing oilpan; w/Accusump
• Oil: Mobil One 5w/30
Transmission
• Manufacturer: Liberty Built/Tremec T-5
• Type: 5-speed
• Gears Ratios: 2.95, 1.94, 1.34, 1.00, .82
• Shifter: Hurst
• Races: 3
• Bellhousing: Quick Time Blowproof
• Clutch: Centerforce single disc
• Pressure Plate: Centerforce Light LS1 11”
• Flywheel: Stock Centerforce Lightweight Chrome Moly LS1
Rear End
• Manufacturer: Nissan R200 Short Nose 3.545:1
• Case: Steel Carrier/ Aluminum rear cover
• Differential: Lim/Slip
• Axles: J30
• Hubs: 300ZX
Body
• Construction: Steel/Fiberglass
• Color: White/Black Stripe
• Splitter
• Rear Wing: Adjustable
Interior
• Kirkey 20 deg layback seat
• Shoulder supports
• Seat is adjustable
• Cool shirt system
• Mild steel 10 point cage
Chassis
• Front Suspension: Mcpherson Strut; Adj. Spring height, Track, Toe, Camber
• Front Anti Rollbar: 18mm/ Adj. Rate & Rod end links
• Rear Suspension: Mcpherson Strut; Adj. Spring height, Track, Toe, Camber
• Rear Anti Rollbar: 23mm/ Adj. Rate & Rod end links
• Shocks: Tokico 5way Single Adj. Shocks
• Brakes: Dual Wilwood master cylinders with balance bar and cockpit adjustable bias
• Brakes: Front/ Wilwood FSLI4 Calipers/Hawk DTC70 Pads
• Brakes: Rear/94 Nissan 300zx Calipers/Hawk Blue Pads
• Steering: Rack & Pinion, 1.5:1 Steering Quickener
• Wheels: 17 x 9.0 Front/ 17 x 10.5 Rear Alum Mustang 500R Replicas
Spares
• Rear Anti Rollbar: 18mm
• 1 extra set of wheels
• Three Rear ends: 4.10:1; 3.90:1; 3.70:1
• Cool suit water conditioner
• Kevlar brake hoses
$22,999.00 O.B.O.
Also available as a negotiable package an Open Trailer with a large toolbox with a tire rack.
Call Bryon @ 225-572-282zero
For pictures and video go to:
http://s664.photobucket.com/user/romebz28/library/240Z%20NASA%20ST2?sort=3&page=1
or
http://s664.photobucket.com/albums/vv4/romebz28
240Z NASA ST2
