2000 Panoz GT-RA # 0051 Price reduced: $21900
Description: Started out as a Panoz School Car. Never wrecked. Has been extensively improved and upgraded. Including a Ford Small Block crate race engine (500HP, see below*) which replaced the school Ford Explorer 302 HO engine (250HP). Recent eye surgery halts my racing so I must sell.
This car is easy to drive fast and is very predictable. A great “track day” car. Also may be vintage eligible depending on your local race groups. I drove with ARC Racing (American Racing Club) in Northern California, which is part of NCRC. The car has an SCCA Northern California log book.
Basically neutral handling. Brakes are very powerful, especially when you realize there is no power boost. There is power steering which is not too boosted, gives good feel without killing your arms.
New 3” exhaust and new mufflers. Upgraded instruments from Longacre Racing – Large stepper motor tach and stepper motor Oil temp, Oil Pressure, Water Temp, and Fuel Pressure, see photos.
Excellent power to weight ratio – 2550lbs/480bhp = 5.31 lbs per bhp. That puts this car in really good company: 2017 Viper: 5.24. 2017 Z06: 5.42. 2017 Ferrari 488: 4.90, but that’s a twin turbo.
*Engine:
New upgraded engine, Ford M-6007-Z363FT/RT BOSS Crate Engine with:
Boss 302 4 bolt main block. Bored and Stroked to 363 Cubic inches
Compression Ratio 10.2:1 (Makes 480 bhp/430 lb ft on pump gas)
Ford Perf Z304DA Aluminum heads, high-flow ports. Prime A365 T6 aluminum.
Premium stainless steel valves, 2.02” intake and 1.60” Exhaust
PAC 1219X conical style (beehive) valve springs
Steel Alloy intake and exhaust seats
7/16” ARP rocker studs
Cower Offset Aluminum Roller Rocker Arms (1.65 Ratio)
Manganese-bronze valve guides
63cc CNC’d combustion chamber
Large exhaust ports (1.620” x 1.420”)
New “Shorty” large port headers – matched to the head exhaust ports
SCAT Pro Comp Stroker Lightweight Forged crank
SCAT Pro-Stock I-Beam 5.4” Forged Connecting Rods
Mahle Forged Alloy Pistons, Mahle rings and wrist pins
Crane Hydraulic Roller Tappet Cam (Duration 294/302; Lift 0.563/0.584)
Ford Performance Zero Offset Hydraulic Roller Lifters
Trend Perf Chromoly Push Rods, 6.8” long, 5/16” dia, 0.080 thick wall, Ball ends
Edelbrock Super Victor Intake Manifold, polished and flowed at TechCraft
650 cfm Holly 4 bbl, double pumper
K&N Air filter assembly
MSD Billet Distributor
MSD 6AL with Manual Rev limit set/verification
All ARP hardware, inside and out
Ford Perf Zero balance Aluminum Flywheel, 157 teeth
Ford Perf Neutral Balance Crankshaft Damper
Center Force Clutch and pressure plate
New electric fuel pump and fuel filter
New Ford starter
Dyno shows 414 RWHP at 6200 rpm on pump gas, would make more on race gas with more Distributor advance – dyno sheet included
New windshield (out of a SN95 Mustang so it’s readily available).
Basic Specs:
Chassis: Steel tube frame construction
Body: Thermal-formed Plastic
Steering: Ford Motorsport power rack & pinion
Front Suspension: Double A-arm with H&R coil-over springs with Koni shocks and sway bar
Rear Suspension: Ford 9" (Colman Diff) axle with four links, Watts linkage, sway bar
Brakes: Front and rear disc brakes with 4 piston Brembo calipers and PFC discs and pads
Dimensions:
Track - 65"; Width - 75";
Wheel Base - 107";
Length - 171";
Height - 52";
Weight - 2550 lbs
Safety Features:
New 6 point Race Quip belts (passenger and driver), window net, composite racing seats, full roll cage with door side bars
New 5lb Stroud Safety Halon on board fire system
Other info:
Longacre Stepper motor gauges: Tach, Oil Pres., Oil Temp, Water Temp, Fuel Pres.
Replaced Pi Research dash which was very had to read
All recommended chassis reinforcements per Panoz have been completed:
Double Shear Brackets for rear trailing arms
Reinforcement plates and ribs on front control arms
Rear shock mount brace
Completely rebuilt Tremec TKO 500 5-speed (Campbell Auto Restoration)
Upgrade from TTK “R” Tremec to handle power of the new engine
Completely rebuilt Coleman (NASCAR) limited slip rear end (Campbell Auto Restoration
Inspected spindles for cracks (since this is a known weak point.)
Recent Fuel Safe brand Fuel Cell – 35 Gal
New Griffin Radiator
New Ford Radiator Header tank
Remote oil filter
New 3 inch exhaust and mufflers. Meets 102 db sound limit easily.
New Optima Red Top Battery
Extra set (4) of 17 inch Ford Racing wheels
Many spares including rotors, pads, shocks, Plexiglass (plastic) rear window, Misc body parts.
Also available:
24 foot Pace enclosed trailer with new SuperWinch 3000 and remote, tire rack, 2 tool chests, work bench and lights, on-board Optima Yellow Top battery.
Powered Trailer dolly (electric) to move/park trailer.
I have receipts, Ford Performance instructions, etc., Plus Panoz specific info.
John O’Boyle
I may be able to deliver within 500 miles of Phoenix, AZ. 
Photos available
  • 1 month later...
Pretty sure this sold as I was watching it on RJ. Sweet car for the money.
