Wishbone suspension adjustment
To make sure I am clear, for ST 5 & 6:
A common strut/strut car -> no adjustment
A fairly common strut/multilink car (~wishbones at one end) -> -0.8
A wishbone/multilink car (~wishbones F & R) -> -1.6
Is this right, or is a one time adjustment even if you have wishbones all round?
  • National Staff
Just one assessment. -0.8.
Thanks.
Maybe the rule would be clearer if it said "front and/or rear"? I was interpreting "front or rear" as meaning front and rear are "scored" separately.
  • 1 month later...
Greg - does the rear trailing arm setup as found in an e36 for example fall into the category of multi link and will then take the .8 hit? Thanks for your help.
  • National Staff
2) If the vehicle has an OEM suspension design utilizing an upper “A-arm” or
“Wishbone” type control arm on either the front or rear suspension, a Modification
Factor will be assessed. Conversion from an alternate design to an “A-arm” or “Wishbone” suspension design using non-OEM parts is not permitted
(front or rear).
The rule does not state "multi-link".
(front or rear).
Isn't multi-link and duel wishbone almost the same, with the potential for multi-link to be somewhat better?
I thought the intent of the rule was to separate so-so Strut based suspension from the better performing wishbone/multilink?
(front or rear).
What is the reason that multi-link does not have a penalty when it delivers many of the benefits of a double wishbone?
(front or rear).
Because miata
  • National Staff
Because miata
Wrong. Miata has an A-arm suspension.
Because miata
Hence why I said because Miata. :wink:
