philstireservice Posted February 7, 2013 Share Posted February 7, 2013 hey guys what are you doing with your hubs on the 4th gen Camaro?......some models have 70.3 in the front and 70.7 in the rear Quote Link to comment Share on other sites More sharing options...
Members Al F. Posted February 7, 2013 Members Share Posted February 7, 2013 Are you referring to the lip on the hub that the wheel centers on? If so the answer is if you have a wheel that wont quite fit you sand/file the ID of the wheel a bit Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 7, 2013 Share Posted February 7, 2013 GM used 2 sizes of wheel centering hubs on the rear from 93-02. The 93-97 rear axle centering hub is larger than the 98-02 versions. The fronts are the same for all years best I know. Make the wheels fit the larger size and all will be fine. Quote Link to comment Share on other sites More sharing options...
philstireservice Posted February 7, 2013 Author Share Posted February 7, 2013 GM used 2 sizes of wheel centering hubs on the rear from 93-02. The 93-97 rear axle centering hub is larger than the 98-02 versions. The fronts are the same for all years best I know. Make the wheels fit the larger size and all will be fine. Thanks - the rear is the larger, 70.7 Quote Link to comment Share on other sites More sharing options...
cozog1548534733 Posted February 8, 2013 Share Posted February 8, 2013 GM used 2 sizes of wheel centering hubs on the rear from 93-02. The 93-97 rear axle centering hub is larger than the 98-02 versions. The fronts are the same for all years best I know. Make the wheels fit the larger size and all will be fine. Or use spacers to max. the width out and don't worry about hub fit. Quote Link to comment Share on other sites More sharing options...
philstireservice Posted February 8, 2013 Author Share Posted February 8, 2013 GM used 2 sizes of wheel centering hubs on the rear from 93-02. The 93-97 rear axle centering hub is larger than the 98-02 versions. The fronts are the same for all years best I know. Make the wheels fit the larger size and all will be fine. Or use spacers to max. the width out and don't worry about hub fit. This could be dangerous. Got to make sure the wheel sits on the hub, or some sort of hub. Quote Link to comment Share on other sites More sharing options...
Glenn Posted February 9, 2013 Share Posted February 9, 2013 Not really. These cars are lug centric not hub centric. I've been running 1/2" spacers on my CMC car since 2005. I have no center hub register locating my wheels. Quote Link to comment Share on other sites More sharing options...
nape1548534725 Posted February 9, 2013 Share Posted February 9, 2013 Last year, on the front, I ran 1" worth of spacers stacked on a 2.25" adapter that doesn't register on the hub. Being hub centric is for cake eaters. Quote Link to comment Share on other sites More sharing options...
cozog1548534733 Posted February 10, 2013 Share Posted February 10, 2013 GM used 2 sizes of wheel centering hubs on the rear from 93-02. The 93-97 rear axle centering hub is larger than the 98-02 versions. The fronts are the same for all years best I know. Make the wheels fit the larger size and all will be fine. Or use spacers to max. the width out and don't worry about hub fit. This could be dangerous. Got to make sure the wheel sits on the hub, or some sort of hub. Phil, To max out the allowed track width as defined in the rules, just about all the cars will have to use a spacer of some sort. Most people have been running them safely for a long time in CMC. Quote Link to comment Share on other sites More sharing options...
