CMC#11 Posted May 1, 2013 Share Posted May 1, 2013 I always weigh around 3280-3300 after the race. Using 1 3/4" roll bar tubing made it heavy but even if it were thinner it would still be 70-80 pds overweight. Not sure what else I could pull out that would make it any lighter. Headlights, headlight bracketry, etc. On my fox it was about 15 lbs. Quote Link to comment Share on other sites More sharing options...
suck fumes1548534743 Posted May 1, 2013 Share Posted May 1, 2013 All my brackets and stuff are plastic. Remember my car is 24 yrs newer haha. Quote Link to comment Share on other sites More sharing options...
t500hps Posted May 1, 2013 Share Posted May 1, 2013 SN95 and SN99 racers, We all want close and competitive racing here. Race to race and region to region. I'd rather not dwell on how the rules have changed or how the class has evolved. My focus is forward. We should share what we know that makes us fast and how we can collectively tackle the F-body cars. Let's use this area to share setups, feedback, and updates. April 2013 Mid Ohio Great Lakes MW #302 and I had two very closely matched SN95s. 0.3s off each other in qualifying. Down 2.5-3s off the F-body cars. Video to follow of how close the cars are. Achilles Heal #1 - 4.6l power. I am down 20hp/30tq off the 260/310 max. Power curve is less than optimal. Weight is ~3225 full tank. The power I have is the power this motor will make. Every class rule consideration has been used. Nothing to hide here, happy to produce the dyno chart. I do not believe just adding power will make 3s difference. Achilles Heal #2 - T-45 and 0.67 5th gear. #302 was able to pull me slightly 4th gear v. 4th gear (power shortage on my part). At 5th gear he pulled a car length before the braking zone. He has the RR 5th gear. Currently, car has a 3.73 rear gear. 4th gear terminal speed at 6000 RPM is 120 mph. Group Thought 1: lower rear get to effectively create a 4sp trans. I am leaning towards a 3.31 rear gear. New 4th gear terminal speed would be 135 (139 at limiter). Only the longest of tracks would the speeds reach north of 135 (Road America, etc). 3-4 shift would put the car back at 4600-4700 well within the meat of powerband. Forward actions: Log lateral g-forces for in corner information. Track width is not fully maximized to the rules. Others thoughts and findings? MG #108 GL Total newbie here so bear with what limited info I can give...... I ran HPDE 1-2-3 in my SRT8 Charger before recently buying an already built 96 mustang for CMC. Several of my buddies run CMC and this car had previously ran against them until 2 years ago (so they knew a bit about it). The car shows 259hp/298tq and has 3.27 gears with a stock T45 tranny. Apparently the car was competitive but now most of these guys have moved to 3:73 (or higher) gears and are killing the times they ran against this car. From my reseach and discussions with the guys that know this car I will be going to a 4:10 rear and continue to use a stock T45. At VIR I'm maxing out 100-150 yards before turn 14 in 4th. 5th isn't even working (tranny needs a rebuild). I'm feathering the throttle at about 130 in 4th. The theory is the lower gear will pull harder for 2-4 and allow/force me to run 5th on that stretch. BTW: The previous owner welded the rear. You can really throw the car around but I feel it's going to break soon. Any thoughts? I'm interested in opinions as I claim to know NOTHING at this point.......on the plus side, I'm lined up for comp school at my next event in June!!!!! Quote Link to comment Share on other sites More sharing options...
Smike Posted May 1, 2013 Author Share Posted May 1, 2013 Total newbie here so bear with what limited info I can give...... I ran HPDE 1-2-3 in my SRT8 Charger before recently buying an already built 96 mustang for CMC. Several of my buddies run CMC and this car had previously ran against them until 2 years ago (so they knew a bit about it). The car shows 259hp/298tq and has 3.27 gears with a stock T45 tranny. Apparently the car was competitive but now most of these guys have moved to 3:73 (or higher) gears and are killing the times they ran against this car. From my reseach and discussions with the guys that know this car I will be going to a 4:10 rear and continue to use a stock T45. At VIR I'm maxing out 100-150 yards before turn 14 in 4th. 5th isn't even working (tranny needs a rebuild). I'm feathering the throttle at about 130 in 4th. The theory is the lower gear will pull harder for 2-4 and allow/force me to run 5th on that stretch. BTW: The previous owner welded the rear. You can really throw the car around but I feel it's going to break soon. Any thoughts? I'm interested in opinions as I claim to know NOTHING at this point.......on the plus side, I'm lined up for comp school at my next event in June!!!!! I ran the numbers on a 4.10 and 5th and it will add a lot of shifting for the MW/GL tracks. And T45s 0.67 5th is very hard to turn with a 3.73. I do not see the 4.10 making it a go gear. My game plan is the opposite direction - avoid 5th altogether. PS - congrats on getting ready for comp school! Quote Link to comment Share on other sites More sharing options...
Smike Posted May 1, 2013 Author Share Posted May 1, 2013 3.73 with T45 RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear500 8 10 15 600 9 12 18 700 11 14 21 800 12 16 24 900 14 18 27 1000 15 20 30 1100 17 22 33 1200 18 24 36 1300 20 26 39 1400 21 28 42 1500 23 30 45 1600 24 32 48 1700 26 34 51 1800 27 36 54 1900 29 38 57 2000 30 40 60 2100 32 42 63 2200 33 44 66 2300 35 46 69 2400 36 48 72 2500 38 50 74 2600 39 52 77 2700 41 54 80 2800 42 56 83 2900 44 58 86 3000 45 60 89 3100 47 62 92 3200 48 64 95 3300 50 66 98 3400 51 68 101 3500 53 70 104 3600 54 72 107 3700 56 74 110 3800 57 76 113 3900 59 78 116 4000 60 80 119 4100 62 82 122 4200 63 84 125 4300 65 86 128 4400 66 88 131 4500 68 90 134 4600 69 92 137 4700 71 94 140 4800 72 96 143 4900 74 98 146 5000 75 100 149 5100 77 102 152 5200 78 104 155 5300 80 106 158 5400 81 108 161 5500 83 110 164 5600 84 112 167 5700 86 114 170 5800 87 116 173 5900 89 118 176 6000 90 120 179 3.31 w/T45 RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear500 8 11 17 600 10 13 20 700 12 16 24 800 14 18 27 900 15 20 30 1000 17 22 34 1100 19 25 37 1200 20 27 40 1300 22 29 44 1400 24 31 47 1500 25 34 50 1600 27 36 54 1700 29 38 57 1800 30 40 60 1900 32 43 64 2000 34 45 67 2100 36 47 71 2200 37 49 74 2300 39 52 77 2400 41 54 81 2500 42 56 84 2600 44 58 87 2700 46 61 91 2800 47 63 94 2900 49 65 97 3000 51 67 101 3100 52 70 104 3200 54 72 107 3300 56 74 111 3400 58 76 114 3500 59 79 118 3600 61 81 121 3700 63 83 124 3800 64 85 128 3900 66 88 131 4000 68 90 134 4100 69 92 138 4200 71 94 141 4300 73 97 144 4400 74 99 148 4500 76 101 151 4600 78 103 154 4700 80 106 158 4800 81 108 161 4900 83 110 165 5000 85 112 168 5100 86 115 171 5200 88 117 175 5300 90 119 178 5400 91 121 181 5500 93 124 185 5600 95 126 188 5700 96 128 191 5800 98 130 195 5900 100 133 198 6000 101 135 201 4.10 w/T45 RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear500 7 9 14 600 8 11 16 700 10 13 19 800 11 15 22 900 12 16 24 1000 14 18 27 1100 15 20 30 1200 16 22 33 1300 18 24 35 1400 19 25 38 1500 20 27 41 1600 22 29 43 1700 23 31 46 1800 25 33 49 1900 26 35 52 2000 27 36 54 2100 29 38 57 2200 30 40 60 2300 31 42 62 2400 33 44 65 2500 34 45 68 2600 36 47 70 2700 37 49 73 2800 38 51 76 2900 40 53 79 3000 41 54 81 3100 42 56 84 3200 44 58 87 3300 45 60 89 3400 46 62 92 3500 48 64 95 3600 49 65 98 3700 51 67 100 3800 52 69 103 3900 53 71 106 4000 55 73 108 4100 56 74 111 4200 57 76 114 4300 59 78 117 4400 60 80 119 4500 61 82 122 4600 63 84 125 4700 64 85 127 4800 66 87 130 4900 67 89 133 5000 68 91 136 5100 70 93 138 5200 71 94 141 5300 72 96 144 5400 74 98 146 5500 75 100 149 5600 76 102 152 5700 78 104 155 5800 79 105 157 5900 81 107 160 6000 82 109 163 Quote Link to comment Share on other sites More sharing options...
t500hps Posted May 2, 2013 Share Posted May 2, 2013 Forgive me....but what am I looking at here??? 3.73 with T45RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear500 8 10 15 600 9 12 18 700 11 14 21 800 12 16 24 900 14 18 27 1000 15 20 30 1100 17 22 33 1200 18 24 36 1300 20 26 39 1400 21 28 42 1500 23 30 45 1600 24 32 48 1700 26 34 51 1800 27 36 54 1900 29 38 57 2000 30 40 60 2100 32 42 63 2200 33 44 66 2300 35 46 69 2400 36 48 72 2500 38 50 74 2600 39 52 77 2700 41 54 80 2800 42 56 83 2900 44 58 86 3000 45 60 89 3100 47 62 92 3200 48 64 95 3300 50 66 98 3400 51 68 101 3500 53 70 104 3600 54 72 107 3700 56 74 110 3800 57 76 113 3900 59 78 116 4000 60 80 119 4100 62 82 122 4200 63 84 125 4300 65 86 128 4400 66 88 131 4500 68 90 134 4600 69 92 137 4700 71 94 140 4800 72 96 143 4900 74 98 146 5000 75 100 149 5100 77 102 152 5200 78 104 155 5300 80 106 158 5400 81 108 161 5500 83 110 164 5600 84 112 167 5700 86 114 170 5800 87 116 173 5900 89 118 176 6000 90 120 179 3.31 w/T45 RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear500 8 11 17 600 10 13 20 700 12 16 24 800 14 18 27 900 15 20 30 1000 17 22 34 1100 19 25 37 1200 20 27 40 1300 22 29 44 1400 24 31 47 1500 25 34 50 1600 27 36 54 1700 29 38 57 1800 30 40 60 1900 32 43 64 2000 34 45 67 2100 36 47 71 2200 37 49 74 2300 39 52 77 2400 41 54 81 2500 42 56 84 2600 44 58 87 2700 46 61 91 2800 47 63 94 2900 49 65 97 3000 51 67 101 3100 52 70 104 3200 54 72 107 3300 56 74 111 3400 58 76 114 3500 59 79 118 3600 61 81 121 3700 63 83 124 3800 64 85 128 3900 66 88 131 4000 68 90 134 4100 69 92 138 4200 71 94 141 4300 73 97 144 4400 74 99 148 4500 76 101 151 4600 78 103 154 4700 80 106 158 4800 81 108 161 4900 83 110 165 5000 85 112 168 5100 86 115 171 5200 88 117 175 5300 90 119 178 5400 91 121 181 5500 93 124 185 5600 95 126 188 5700 96 128 191 5800 98 130 195 5900 100 133 198 6000 101 135 201 4.10 w/T45 RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear500 7 9 14 600 8 11 16 700 10 13 19 800 11 15 22 900 12 16 24 1000 14 18 27 1100 15 20 30 1200 16 22 33 1300 18 24 35 1400 19 25 38 1500 20 27 41 1600 22 29 43 1700 23 31 46 1800 25 33 49 1900 26 35 52 2000 27 36 54 2100 29 38 57 2200 30 40 60 2300 31 42 62 2400 33 44 65 2500 34 45 68 2600 36 47 70 2700 37 49 73 2800 38 51 76 2900 40 53 79 3000 41 54 81 3100 42 56 84 3200 44 58 87 3300 45 60 89 3400 46 62 92 3500 48 64 95 3600 49 65 98 3700 51 67 100 3800 52 69 103 3900 53 71 106 4000 55 73 108 4100 56 74 111 4200 57 76 114 4300 59 78 117 4400 60 80 119 4500 61 82 122 4600 63 84 125 4700 64 85 127 4800 66 87 130 4900 67 89 133 5000 68 91 136 5100 70 93 138 5200 71 94 141 5300 72 96 144 5400 74 98 146 5500 75 100 149 5600 76 102 152 5700 78 104 155 5800 79 105 157 5900 81 107 160 6000 82 109 163 Quote Link to comment Share on other sites More sharing options...
Smike Posted May 2, 2013 Author Share Posted May 2, 2013 3rd, 4th, and 5th gears with each rear end ratio. I left out 1st and 2nd...format was good on my end. Looks like it got murdered a bit after it posted. Quote Link to comment Share on other sites More sharing options...
aschroeder Posted May 2, 2013 Share Posted May 2, 2013 Not a SN95/99 owner, but I've spent a good deal of time pondering ratios so I thought I'd chime in Here is a T-45 w3.73s vs. a T-45 w3.27s (essentially moving 4th to a usable fifth, but I would imagine 2nd and 3rd would still be too wide for mid speed corners/straights) Here is a T-45 w3.73s vs. my setup: a TKO600 with the .82 5th and 3.73s (here you can see what I mean, the TKO600 sits entirely within the T-45 ratios and only drops about 1,100 rpm upshifting to 5th) Here is a T-45 w3.27s up against the same TKO600 (it is a good compromise, but you are still left with 3 usable gears to the TKOs 4 and 140mph terminal velocity if you are wrapping to 6) Quote Link to comment Share on other sites More sharing options...
Smike Posted May 2, 2013 Author Share Posted May 2, 2013 Interesting. Downside, its a full transmission swap. The RR 5th gear is $$$ over a gear change. For those mid/fast sweepers we have, 3rd would be most used gear. Quote Link to comment Share on other sites More sharing options...
Dillon Posted August 26, 2014 Share Posted August 26, 2014 Was searching for info on gearing for my '00 (4.6, T45, stock 3.27) and found this thread. I know we don't have too many SN95/99 racers in the RM region, but there are (or have been) a few...anyone know if any of them run a 4.10? I was thinking about a 3.73, but that seems like it would just force a shift to a still-not-usable 5th gear on longer straights (High Plains) or banks (PPIR). Yet I worry that a 4.10 could actually be SLOWER overall, since it would force me to shift more in the mid-speed corners. I'm not too familiar with tracks in other regions, so it's hard to compare, but anyone running a 4.10 feel free to chime in. Quote Link to comment Share on other sites More sharing options...
Members Dustin M. Posted August 26, 2014 Members Share Posted August 26, 2014 I'm not a Ford guy, but my car is undergeared. My 1-3 act like I have a 4.10 out back compared to the others with normal T56s. I WOULD NOT put a 4:10 in that car. Way too much gear. Having a ~70mph capable 2nd gear is a good place to be IMO. Mine does about 55 so it's pretty much worthless and I end up lugging 3rd, an 85mph gear, through 40mph corners most of the time. Think of how fast most corners are taken when trying to decide on a good gear set. Also consider that on DOT R compounds that will be faster than what you currently have under the car. Quote Link to comment Share on other sites More sharing options...
t500hps Posted August 27, 2014 Share Posted August 27, 2014 Was searching for info on gearing for my '00 (4.6, T45, stock 3.27) and found this thread. I know we don't have too many SN95/99 racers in the RM region, but there are (or have been) a few...anyone know if any of them run a 4.10? I was thinking about a 3.73, but that seems like it would just force a shift to a still-not-usable 5th gear on longer straights (High Plains) or banks (PPIR). Yet I worry that a 4.10 could actually be SLOWER overall, since it would force me to shift more in the mid-speed corners. I'm not too familiar with tracks in other regions, so it's hard to compare, but anyone running a 4.10 feel free to chime in. I have the same.....(1996, 4.6L, T45, 3.27). I too thought about a switch and even mapped out each track I run marking where I currently shift and where I WOULD shift using 3.73 or 4.10 gears from the charts in this thread. Makes no sense for me to switch gears IMO. (On our tracks I run 4th out to 130-135 mph near redline and I'm not caught "between" gears anywhere) Quote Link to comment Share on other sites More sharing options...
Dillon Posted August 27, 2014 Share Posted August 27, 2014 Huh. I guess I will stick with the 3.27 for the foreseeable future. I haven't even had the car on track yet, but that should be changing soon! Anyway, I was just really hoping for some extra pickup without having to drop weight, since (at least for now) my car is remaining a street car. It doesn't feel slow by any means, but, it sure would be a more fun street car with a taller gear, and I was trying to figure out if that would translate well to the track or not. Quote Link to comment Share on other sites More sharing options...
blk96gt Posted August 27, 2014 Share Posted August 27, 2014 I have the same as t500hps ('96, 4.6, T45, 3.27). I originally had 3.73's, and not having a RR 5th was killing me at TWS. At this point I don't plan on ever going back to 3.27's even if I had a RR 5th. Quote Link to comment Share on other sites More sharing options...
Smike Posted August 27, 2014 Author Share Posted August 27, 2014 Was searching for info on gearing for my '00 (4.6, T45, stock 3.27) and found this thread. I know we don't have too many SN95/99 racers in the RM region, but there are (or have been) a few...anyone know if any of them run a 4.10? I was thinking about a 3.73, but that seems like it would just force a shift to a still-not-usable 5th gear on longer straights (High Plains) or banks (PPIR). Yet I worry that a 4.10 could actually be SLOWER overall, since it would force me to shift more in the mid-speed corners. I'm not too familiar with tracks in other regions, so it's hard to compare, but anyone running a 4.10 feel free to chime in. I have the same.....(1996, 4.6L, T45, 3.27). I too thought about a switch and even mapped out each track I run marking where I currently shift and where I WOULD shift using 3.73 or 4.10 gears from the charts in this thread. Makes no sense for me to switch gears IMO. (On our tracks I run 4th out to 130-135 mph near redline and I'm not caught "between" gears anywhere) I went with 3.31s and have rocked it ever sense. Saved time in useless shifts at all the GL/MW tracks. Quote Link to comment Share on other sites More sharing options...
