RacerX1548534736 Posted August 22, 2013 Share Posted August 22, 2013 I am finishing up the installation of the new spec carbed 350 engine in the Firebird and discovered that the Vortec exhaust ports do not have the wide bolt pattern that is required on the passenger side rear port. I've looked at almost every manifold available for F-bodies and all of them have the same problem. The only ones that I can find are the ones that came on the Vortec head trucks. Can I use these legally? What are some of the other guys using? Gary Texas Region CMC 20 Quote Link to comment Share on other sites More sharing options...
roadracerwhite Posted August 23, 2013 Share Posted August 23, 2013 I use the regular f-body manifolds and made a contraption to bolt it on the passenger side using the bolt holes on the back of the head. I think you could use manifolds for the lt1. I believe they have the bolt in the right location. I just got some in case my contraption wasn't going to work. In the past I have ran without the bolt, it leaks after a while and you have to replace the gasket. I looked at using the truck manifold on the passenger side, but I don't think it will fit. I think the exit would come out into the fiewall. Quote Link to comment Share on other sites More sharing options...
syedshah20 Posted December 11, 2014 Share Posted December 11, 2014 Please correct me if I'm wrong, but by following section 7.8.6 in the CMC rules, I can gut the dash to accommodate the roll cage installation as long as I retain the dash pad and the main dash structure remains securely installed in the OEM location along with the steering column in the OEM location. AND I can remove any vents, switches, controls, glove box doors, ash trays, airbags, gauges, gauge clusters, etc. as long as any openings larger than 6 sq. inches have metal or plastic replacement covers installed in place of those items. Quote Link to comment Share on other sites More sharing options...
Members Al F. Posted December 12, 2014 Members Share Posted December 12, 2014 Sounds about right Quote Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2015 Share Posted February 11, 2015 The article above is built was interests me as much as ever. Quote Link to comment Share on other sites More sharing options...
