cwreese Posted August 7, 2014 Share Posted August 7, 2014 I recently purchased a CMC Mustang. Its a '95. Didn't purchase it from the builder and was unable to get many questions answered. Here's my question; The transmission is a 4-speed. Before I climb under it to try and find some identifying numbers, or tear it apart to see if anything is broken, has anyone heard of modifying a 5-speed to eliminate 5th gear? Maybe to save weight? I've driven it once at Buttonwillow and only hit 5500rpm at the end of the long "dragstrip" straightaway. The rear gear is 3.55. Doesn't appear to be a problem, I'm just suspicious. Quote Link to comment Share on other sites More sharing options...
t500hps Posted August 7, 2014 Share Posted August 7, 2014 I have a 96 CMC mustang with a 3:27. Although my tranny has 5th, I never use it. It has been suggested I have 5th removed to save weight but haven't bothered. FYI: I red-line around 130mph in 4th which is just at the end of our fastest straight. With 3:55's I suspect your only hitting about 115-120mph in 4th......is that enough for your tracks? (or maybe the tracks in the area where the car was built) Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 7, 2014 Share Posted August 7, 2014 I didnt think removing gears from the trans was legal. Didnt there used to be a rule against it? Quote Link to comment Share on other sites More sharing options...
BADVENM Posted August 7, 2014 Share Posted August 7, 2014 How would this be enforced if it were illegal? Quote Link to comment Share on other sites More sharing options...
suck fumes1548534743 Posted August 7, 2014 Share Posted August 7, 2014 You can pull the tail shaft off the tremec transmissions without removing the whole thing and look. Pretty easy to police. Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 8, 2014 Share Posted August 8, 2014 Put it on jack stands and make sjre each gear moves the wheels. Quote Link to comment Share on other sites More sharing options...
aschroeder Posted August 11, 2014 Share Posted August 11, 2014 Short of looking at the case or the shifter, theres not a lot to go on. Does it have a 5th gear shift location but no engagement? Or just 4 forward gears and reverse? Also, are you planning on heading to any NASA events this year? I found myself taking the year off, but wouldn't mind meeting up. Quote Link to comment Share on other sites More sharing options...
nape1548534725 Posted August 18, 2014 Share Posted August 18, 2014 Does it have external linkage? If so, 4 speed for sure. Super T10s are common in SCCA ASedan cars, which is what CMC loosely evolved from. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 11, 2015 Share Posted March 11, 2015 That's cool... i had been thinking about doing something similar, in only 2 or three colors like an old school movie poster. Quote Link to comment Share on other sites More sharing options...
cwreese Posted March 11, 2015 Author Share Posted March 11, 2015 It was a T5. 5th gear was removed and the detent plate in the shifter was welded up so you couldn't "accidently" go to 5th. Tranny has bee thrown in the scrap metal bin. It was cheaper to buy new than try and buy all the parts to put 5th back. I learned a lesson buying this "race ready" car. I was told it was turn-key. Turns out I had to pull both rear axles and replace all the studs (raced with loose lug nuts), replace both rear wheels, replace the drive shaft (over .030" out of round), and now I've replaced the transmission. Haven't raced yet! Oh well, experience... Quote Link to comment Share on other sites More sharing options...
