dbrad Posted August 19, 2015 Share Posted August 19, 2015 I've read the 2015 rules and searched this forum but am not clear regarding my steering column swap. I have an 1988 Mustang GT (tilt column) and it's going bad. Understand the replacement needs to be OEM but wanted to use one from a 1990 Mustang GT since it is not a tilt column. What is throwing me off is 7.8.2 ending in " , but the OEM steering column must be used." I am taking that to mean literally as an 88 must be used. Hope I am over thinking and wrong? Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 20, 2015 Share Posted August 20, 2015 Find the update/backdate rule. It allows parts to be used on cars that fall in the same model groups found in the eligible models list. Quote Link to comment Share on other sites More sharing options...
dbrad Posted August 20, 2015 Author Share Posted August 20, 2015 Thanks Glenn - Section 7.3 Guess I need to stop working on the car and go back and develop some fundamental reading and understanding skills. The irony is I have a hard copy of the rules printed out and notes in the margins all over the place except for 7.3 & 7.4. In the example within 7.3, the rules distinguish between early and late GM and therefore not interchangeable. Since the Fords are all grouped as "Early Ford", take that to mean I can swap SN95 parts into my Foxbody mustang (non body components). Not that I am looking to do so, just trying to understand the rule. Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 20, 2015 Share Posted August 20, 2015 You understand just fine. Cliff notes..... advantage Ford.. I do the same with the rules....... inked up hard copy. Quote Link to comment Share on other sites More sharing options...
