rob_h Posted July 6, 2019 Share Posted July 6, 2019 Hi, If running a fuel cell, is rendering the stock fuel tank non-op by cutting holes in it an alternative to removing it? Rob Quote Link to comment Share on other sites More sharing options...
Administrators Roman V. Posted July 10, 2019 Administrators Share Posted July 10, 2019 On 7/6/2019 at 10:31 AM, rob_h said: Hi, If running a fuel cell, is rendering the stock fuel tank non-op by cutting holes in it an alternative to removing it? Rob Nope. 3.4. Fuel tanks / cells 3.4.1 If a fuel cell is installed, the OEM tank, if applicable, must be removed. Quote Link to comment Share on other sites More sharing options...
rob_h Posted July 10, 2019 Author Share Posted July 10, 2019 (edited) Hi Roman, How do we submit a rule change request? I'd like to propose that an non-op tank be allowed, or that an under body panel no larger than the surface area than the bottom horizontal surface of the stock fuel tank be allowed to to be installed in the location of the stock fuel tank (if removed). Edited July 10, 2019 by rob_h Quote Link to comment Share on other sites More sharing options...
Administrators Roman V. Posted July 10, 2019 Administrators Share Posted July 10, 2019 1 minute ago, rob_h said: Hi Roman, How do we submit a rule change request? I'd like to propose that an in-op tank be allowed, or that an under body panel no larger than the surface area than the bottom horizontal surface of the stock fuel tank be allowed to to be installed in the location of the stock fuel tank (if removed). What is an in-op tank? You meant non-op? What is the use case? Why would you want to leave the tank in there? Roman Quote Link to comment Share on other sites More sharing options...
rob_h Posted July 10, 2019 Author Share Posted July 10, 2019 3 minutes ago, Roman V. said: What is an in-op tank? You meant non-op? What is the use case? Why would you want to leave the tank in there? Roman Roman, yes I meant non-op. I would like to keep something there to reduce drag and act as a debris shield. Quote Link to comment Share on other sites More sharing options...
Administrators Roman V. Posted July 10, 2019 Administrators Share Posted July 10, 2019 5 minutes ago, rob_h said: Roman, yes I meant non-op. I would like to keep something there to reduce drag and act as a debris shield. Got it. Will get back to you here on this question. Quote Link to comment Share on other sites More sharing options...
djqd36 Posted August 21, 2019 Share Posted August 21, 2019 Any update? Thanks! Quote Link to comment Share on other sites More sharing options...
National Staff Jeremy C. Posted August 30, 2019 National Staff Share Posted August 30, 2019 On 7/10/2019 at 6:35 AM, rob_h said: Roman, yes I meant non-op. I would like to keep something there to reduce drag and act as a debris shield. This request was approved and processed. New rules have been published. Quote Link to comment Share on other sites More sharing options...
