Karl Poeltl Posted July 30, 2019 Share Posted July 30, 2019 Description This car was professionally built to compete in the SCCA World Challenge Touring car series in the mid-2000's. No expense has been spared. It is currently equipped with a freshly rebuilt (9/2018) 3 liter engine producing approx 360hp at the rear wheels And would slot right into GTS4 or a similar class. . Below is an itemized list of items that are in the car. The parts in the chassis and the engine add up to over $110k, not to mention the labor...Check out the engine build details at http://www.forgedpistonparts.com/blog/bmw-e46-m54b30-engine-build/ (The only difference being this time we rebuilt it with 2 compression rings to get longer engine life.) I didn't see a way to add pictures to this posting but can send you any you might be interested in. Rear subframe reinforcement kit Subframe solid AL bushings Differential solid AL bushings Enigine solid AL mounts Trans solid AL mounts Rear trailing arm spherical bearing kit Spherical bearing cartridges for upper control arm - inner Spherical bearing cartridges for lower wheel upright - outer Spherical bearing cartridges for upper wheel upright - outer Caster mount custom spherical bearing kit Front control arm outer spherical bearing kit Custom front Camber Plates Media blast undercoating and strip to bare metal Motec M600 with CAM control & Max data memory Motec Harness with Ignitors, MAP, BAP & Lambda sensors Moton Double adjustable Motorsport shocks Moton upper rear shock mounts Motec Fuel Pressure sensor Motec Oil Pressure sensor hypercoil springs x 4 Wheel - BBS x 4 (8 x 17) Wheels - SSR x 4 (8 x 17) Wheels - Team Dynamics x 4 (9 x 17) wheel spacers Brembo Motorsports 332 x 32mm front Rotors (x2) ( 1 weekend) Brembo front calipers from 993 Porsche Stoptech front brake rotor hats Custom front mounting brackets Stoptech Stainless steel brake lines Cage tied to chassis at A and B pillars chassis, cage extends to Front and rear strut towers. Chassis seam welded Customs AL Radiator Custom Air Box Fluidyne 650 Engine Oil Cooler Auto Verdi dry sump Reduction pulley for dry sump Brown & Miller Oil hoses for dry sump tank Brown & Miller Wiggins fittings & hoses for pump Through firewall grommets for dry sump hoses Petterson 5 gallon oil tank Peterson - Micro filter for dry sump Custom oil takeoff on block for oil cooler & dry sump Headers - stainless steel with Swain coating Blanton rear limited slip differntial with 3.91 gear Optic Armor lexan windshield Rear lexan window Assorted factory BMW WTTC race parts Coolant hoses & couplers- assorted Davies Craig electric water pump Tilton 5.5" 2 plate clutch & Flywheel VAC Motorsports Adapter for Tilton throw out bearing Deist Transmission balistic blanket Turner Motorsports Rear Lower adjustable control arms Wheel stud kit with nuts hood pin kits assorted NAS Fasteners Fiber Imaged Carbon Fiber hood Fiber Images Carbon Fiber deck lid World Challenge Crawford Composites wing Tilton Dual Master pedal setup Tilton master cylinders for Brake Tilton clutch master cylinder Sparco Steering wheel Sparco Hub adapter Snap-off Quick disconnect World Challenge approved BMW front bumper cover Front splitter 2 tow strap Schroth Hans 6 point Harness Hotchkis Front sway bar Custom front drop links Custom Tie rods with Bump Steer adjust Brake line end fittings Roll Bar padding Helmet net M3 side mirrors Optima Battery yellow top battery Kill switch Fire protection system 4 liters AFFF BMW Mini Cooper Electric Power steering pump custom hoses & fittings finned rear diff cover for heat extraction Non sunroof roof skin Burn stainless muffler & assorted stainless parts Side exhaust with Burns Stainless mufflers Canton coolant expansion tank 14" coolant fan 24 lb coolant cap Canton coolant catch can K&N filter in custom air box Racetech seat Racetech AL seat bracket Front CL 4001RC6E pads Rear CL 4001RC6E pads Canton remote oil filter housing Peterson dry sump pressure regulator Mandrel drive for dry sump - assorted parts Custom spindles - front Custom AL front & rear bumper brackets Engine build details below: Arrow solid lifter kit ARP head stud kit Head & porting work Block & crank prep etc… Ferrea 1mm oversize 34mm Intake valve Ferrea Exhaust valves Ferrea Titatium retainers Ferrea spring seat locator Iwis racing timing chain Ferrea valve springs Custom World Challenge approved camshafts, 10.5 mm lift Lash caps DLC coating of cam shafts precision wrist pins BMW E46 M3 IDA throttle body Custom adapter fir Throttle bodeis TMW Fuel Press regulator ATI harmonic Balancer Pauter Rods Wossner custom forged Pistons Peterson fuel filter 35 micron Custom airbox Main bearings lower end gasket set upper end gasket set Iwis racing intake valve chain new Valve chain tensioner new chain guides chain guide rail larger Fuel injectors fuel rail modified ARE dry sump pan Quote Link to comment Share on other sites More sharing options...
Joe B Posted December 31, 2019 Share Posted December 31, 2019 Hello, still for sale? If it is, can you please send some pics? thanms Quote Link to comment Share on other sites More sharing options...
