farberio Posted December 4, 2019 Share Posted December 4, 2019 Price: 15k Mazda RX7 setup for ST4 racing, or turbo it for ST2-3. Please see photos here:https://photos.app.goo.gl/dhEPA71Z4AnbcPpu7 Engine Keg: S5 Turbo Block, Street Ported Lapped iron’s 4 years ago Brand New housings FD Rotors, Scalloped, Balanced by Carlos Lopez Ceramic Apex Seals NRS Gray OEM Seals otherwise Motor built by Shook Motorsports, clearances for Turbo Accessories RB Intake Manifold Mindtrain exhaust - parts to fabricate new custom exhaust Speed Technology/efi Hardware Race ITBs, multiple stacks Rising RPM Fuel Rail 2x2000s, primaries only. FD Alternator Dual Pulley System Rising RPM Oil block & Fuel Passthrough (Super easy) Single Coil Conversion w/Custom MSD Wires Stainless Oil Cool Lines Large Radiator, custom E-fan Oil Cooler Flushed and Restored Brakes TII Brakes/normal rotors Porterfield R4 brakes Brake master cylinder Brace Electronics Haltech Platinum Sport 1000 Haltech CAN Hub Haltech Wideband Haltech IQ3 Dash Tunes for Gas and E85 Drivetrain - New Fluid for Every Season Mazdatrix Aluminum Racing Flywheel, 4.75 lbs Quartermaster 5.5” Clutch v-drive RX8 S2 Trans purchased New MX5 Shifter Conversion for 5% shorter throw RX8 S2 Shift Knob Custom RX8 to NA Diff Driveshaft NA Rear Diff, Clutch Pack LSD Wheels/Tires 2 Sets Stickers Hooser A7 245/45R17 - Old 3 Sets Stickers Continental Racing R7 245/40R17 - 2017 2 Sticker 245/45R17 R7s 2017 3 sets Enkei Aluminum 8” x 17 1 set 8.5 x 17 Enkei RPF1 - uses front spacers to clear ARP studs Gorilla Long stem open nuts Fuel ATL 115 15 gal fuel tank ATL Fuel Kit (Walboro something or other) Brandname fuel regulator Canton Racing Fuel Filter AN Lines everywhere, mostly kevlar braided for weight Suspension Racing Beat front sway bar Racing Beat Sway Bar Endlinks NO rear bar AWR Racing Front Strut Tower AWR Individual rear Camber Adjusters AWR Rear Camber Link (set to stock length) BC Racing ER (external reservoir 2-way) 6.5/5k springs Delrin Bushings Motorsports diff mount Aero Custom Front Splitter made from Alumalite APR GTC-200 60.5” Carbon Wing - Custom aluminum mounts Weight Min Weight 2280 Typically Cross scales at 2350ish with 190lb driver Fiberglass Hood Fiberglass and lexan hatch Fiberglass Front Fenders Safety Cage passes NASA Safety Kirky 17” Intermediate Road Race Seat Fire System Schroth Cam Lock Seat Belts driver/passenger (expired for Racing) Schroth Window Net Cool Suit - Mounts to passenger seat mounts Battery relocated to behind passenger seat with fuse to breaker This car is great for beginners as well, I can supply extras such as storage, spare race day parts, fuel jugs, etc for extra $. Quote Link to comment Share on other sites More sharing options...
