henry_v Posted January 10, 2006 Share Posted January 10, 2006 G Force T5 Dog Ring Straight Cut Close Ratio Road Race Transmission. Clutchless upshifting and a 5th gear that keeps you in the powerband! Please check out: http://www.gforcetransmissions.com/tran_gt-5.asp Gear ratios: 2.46/1.54/1.22/1.00/0.90. Close Ratio Gearset. Upgraded High Nickel Mainshaft. 0.90 Overdrive. Bronze shift forks. All gears REM polished. Steel Throwout Bearing Retainer. Cluster Support Plate. Use the 79-93 T5 bell/scattershield. 26 spline input (26 spline 10.5 King Cobra HD disc included). Professionally built by G Force Transmissions. Over $3500.00 invested. $3500.00 OBO. Chicagoland. Henry V [email protected] Quote Link to comment Share on other sites More sharing options...
