2003 Corvette Z06 with many HPDE upgrades - Marcy, NY
pt_webster@hotmail.com
 Share
Electron Blue 50th Anniversary Edition Z06.  Chassis miles: 51,000.  Engine & Transmission miles: <1,200.  Horsepower:  515 Crank/450 Wheel.  Torque:  495 Lb-ft Crank/ 430 Lb-ft Wheel.
Great HPDE/Track Day Car!
Newly installed drivetrain components: Thompson Motorsports 416 cubic inch LS3 engine; Diamond pistons; custom grind cam; Johnson slow bleed lifters and lifter trays; ARP balancer bolt; GM pushrod set; Smith Brothers rocker trunnion upgrade; GM timing gear, tensioner and ARP cam bolts; IWIS timing chain; Melling high volume oil pump; GM water pump gasket; GM manifold gasket; GM head gaskets; spark plugs; spark plug boot set; Z06 clutch kit, bearing and flywheel; ARP flywheel bolts;  GM slave cylinder; LS3 Injectors; CNC ported cylinder heads; GM intake gaskets; GM front and rear main seals; GM front and rear cover gaskets; A/C tensioner pulley; A/C idler pulley; engine idler pulley; A/C compressor belt; engine serpentine belt; GM manifold studs and bolts; Elite oil catch can; RPM Level 5 transmission; Torque Tube bearings and slinger; Driveshaft coupler.  All work performed by New Age Hotrods in New York Mills, NY.
Other aftermarket components include: Halltech Cold Air Induction System, CCW SP505 Rims, Procar Evolution Series suspension seats, Brey-Krause harness bar, carbon fiber raised hood, molded spoiler, Euro taillights, Mid-America Motorworks cat-back exhaust, 160 degree thermostat, Carbotech brake pads (track and street), DRM engine oil cooler, DRM transmission cooler, BBK Underdrive Pulley, Hurst short-throw shifter, dual JBL stereo amplifiers, JBL subwoofer.
Over $45,000 invested in upgrades.  Asking $28,500.
Also includes stock seats and set of four 18x10.5 OEM Z06 Speedline Rims with Nitto NT555R Tires.
 Share
