Shooting Brake Posted March 5, 2021 Posted March 5, 2021 (edited) I’m prepping a friend’s E36 M3 for ST5, and need a clarification. What would a Rogue Engineering adjustable rear control arm fall under in Paragraph 6.1.9 Suspension Limitations: 4) Control arms, camber arms/links...or 6) Non-OEM metallic and/or spherical design...control/camber/toe arms/links? Thank you. Edited March 5, 2021 by Shooting Brake Nomenclature Quote
National Staff Greg G. Posted March 5, 2021 National Staff Posted March 5, 2021 “6) Non-OEM metallic and/or spherical design replacement suspension bushing modifications on control/camber/toe arms/links, panhard rods, watts links, and torque arms shall be assessed a Modification Factor which is in addition to and additive to #4 & #5 above.” Both 4 & 6. The R.E. website says that they use spherical joints, and they are clearly aftermarket. Quote
Tansar_Motorsports Posted March 5, 2021 Posted March 5, 2021 Better off going with offset delrin bushings in stock suspension arms. To get the increased camber without the penalty. Quote
