Azdesert50 Posted May 3, 2021 Posted May 3, 2021 (edited) Looking to sell my 2004 Mazdaspeed MX-5 Miata, It is set up for HPDE, I have converted from a street car to track use, can be turned back to a street car but ECM, injectors, and seat mounting points will have to be reinstalled. I ran it for about two years in Arizona at Wild horse pass and AMP tracks. I am selling for medical issues and have raced it last at the end of 2019. it will come with a 1990 Miata hard top but still has soft top under it. I will try to remember what was done I will miss a few things but you can always email me and ask question Update: no hardtop-sold 3.63 gears (factory 4.10)- better shifting with 6 speed CFS Aluminum Radiator Stop tech front rotors and track pads 15x8 rims with Nitto tires(about 1 year of use) Meister coil overs urethane bushings Flying Miata downpipe with cat flying Miata computer and 24lb injectors, UMS dyno tuned 170 hp at the wheels stock turbo Flying Miata intake kit bolt in Blackbird Fabworx roll bar Aluminum door panels, still has glass and power window(driver side is having problem) was going to remove Miata roadster Shifter No radio and removed antenna No interior but do have some stock stuff quick release steering wheel, no air bags for driver or passenger side Aluminum seat with 6pt harness bolted to floor with factory seat humps removed Still have ac and heater set up 87k miles on car Hood vents(on hot AZ days it would get 3/4 on temp, with vents it stays at 1/2) Exedy raceing clutch, with Flyin Miata flywheel Paint is still good, has dent on passenger front fender, was like that when bought as street car I am located in Buckeye, AZ If you have any question just at John I will also have a trailer for sale but want to see if the car sells first sorry about the pics I could not get the pic to not show upside down so I put the sideways Edited November 4, 2021 by Azdesert50 added info, updated photos Quote
