Seefo Posted January 1, 2022 Share Posted January 1, 2022 (edited) So I have owned this car from 2010. I basically track prep'd it through out the years, but started getting into other hobbies (including chump and the such around 2014). There is a lot of history, but I don't want to make a giant ad that's annoying to go through. Car has ~ 81k miles on it. I bought it @ 47k miles. I removed it from insurance for track only around 2012/2013. Its probably got about 10-12k miles on track. from 2012-2015 I did approx. 8-12 track weekends a year. Oil changes every 2-3 track weekends depending on other driving in between, replaced trans+diff fluids every year while actively tracking it. Located in NC (27703 area). MOAR PICS. $6000. History: - Tracked the car in August of 2010 first time. - Slowly added parts/stuff as I got faster/money/time. - Around 2013/2014 I started to plan for PTE. - Scrapped those plans and joined a Chump/ChampCar team around 2015/2016. - Continued tracking the car on the side for fun/HPDE/Instructing. - I basically stopped tracking/racing cars around 2018. - The car has mostly sat there since I sold my tow vehicle around 2019. - Babies happen (~1.5 years ago), and since then I have slowly fixed/ran the car in hopes to sell it/drive it again. The Bad: - The car has been sitting for the better part of the last 3-4 years. - Might be difficult to make street legal (Comes with all the parts though...but still it would not be the most comfortable street car. Parts wise: EGR valve & front o2 comes with the car...may have other emissions related issues but can't remember). - Transmission SOMETIMES has a light grind in 3rd gear near the end of a hard 25 minute session on track. Its happened occasionally with me, but not often enough that I worried about it. Taking it easy on the fast shifts later in sessions will not grind. - Has some dents/dings from tirewalls. Also replaced the front bumper (Front bumper is from a donor car and doesn't match color wise). - Obviously, you will want to tow or plan to get a temp tag for it. The Good: - Car is fast (VIR-F 2.18.9 on 205 NT-01s - See video below of the lap). With some of the additions it comes with, it could be faster than that (not to mention tires). I am also not the greatest driver & if you follow the predictive timer, I lose about a half-second+ in a braking zone. I think the car is probably good for a low 2.17 with the right driver & conditions. - New fluids and its ready to be tracked again (oil & coolant flush already done). - Comes with a metric SHIT TON of replacement parts. - I had a stint in 2017 where I was planning to turbo the car, so it has a vacuum gauge and an AFR. - Replaced fuel and the car ran + drove fine. Starts up great, didn't have any issues on 20+ minutes driving around neighborhoods and back roads. - Weighted in at ~2200 with driver + full fluids. obviously will gain some with a cage. The Modifications: - 2001 front + headlights. - MSM cam + reshim (comes with the original cam) - Lightweight flywheel + flyin miata 1.8 clutch. - Comes with a Square top intake manifold. - Comes with the kia rear gear + pinion ( was/is attractive for a 6 spd swap & PTE) - Oil cooler + Coolant reroute - Wilwood master cylinder + prop. valve (Comes with a bunch of different brake boosters + cylinders for your customization). - Xida club sport (Gen 1?), Spherical top hats, RB Hollow Front, MSM Rear - RB header, Borla 2.25" mandrel exhaust - RaceTech seats + 6 pt. harnesses (ALL EXPIRED) - Oil pressure, Oil Temperature, corrected stock water temp gauge, AFR, & Vacuum gauges. - Depowered & de-sealed Steering rack. - No AC, but retained the blower + ducts for on track defogging. - HAS A HARD TOP. Comes with bolt in brackets. - Doors are gutted. - Poly bushings + Zerk fittings. - 15x8 6ULs (2nd or 3rd gen, not sure). Parts it comes with: - Hardtop - Squaretop manifold - 2 extra front bumpers including a 99 - 1 extra rear bumper - Kia diff - A BUNCH of stock parts, including brake boosters, pads, master cylinders, control arms, stock intake, o2 sensors, fuel injectors, etc. - A second oil thermostat for the oil cooler. - A spare 5 speed trans. - Stock exhaust - A bunch of random other aftermarket parts (longer wheel studs, brackets, etc. etc.) - A lot of cobwebs \ VIR-F Video: https://www.youtube.com/watch?v=X1lQBtxORRQ Walk-around & Neighborhood drive videos Edited January 1, 2022 by Seefo Quote Link to comment Share on other sites More sharing options...
