FS:Canton Oil pan and Oil Pump Pick up
STYLE: Part #15-244T for '86 and up SBC, works with stock starter and includes part# 20-020 SB High Volume pickup free! 7-1/2" shallow, fully baffled for road racing, this pan was designed to fit in late model (82-92) F Bodies. Makes a great Road Race pan, but works equally well for Drag Racing and High Performance street cars. Can be used with cross-over exhaust.
FEATURES: 3 Trap door baffles, removable one way screen windage tray with built in crank scraper, oil temp fitting, magnetic drain plug and, 20mm fitting for low oil warning sender.
SIZE: 7-1/2" Deep, 12" wide, 8-1/4" long sump has a 6 qt. system capacity.
STARTER: 15-244t, Work with stock starter.
PART #’S:
#15-244T pan for 86 and newer blocks with a one piece seal.
#20-020 Pickup for SM. BL. H.V. Pumps.
$300 BIN, save over buying pan and pump pick-up separately, and get it shipped at no extra cost, otherwise $20 standard flat rate shipping.
