Talon Posted February 25, 2006 Share Posted February 25, 2006 I was browsing though the pics for HPDEs and most of the cars have numbers. My question is, are magnetic numbers strong enough to stay on the car while tracking? Where did you get them from? Quote Link to comment Share on other sites More sharing options...
BrianZ Posted February 25, 2006 Share Posted February 25, 2006 The magnetic numbers work on some tracks, and it depends on the car too.. I think gogogear can make them for you. I got mine from Edecals a long time ago. From what I have seen the magnets seem to work better (and a little tape on the leading edge) Quote Link to comment Share on other sites More sharing options...
zuperdave Posted February 26, 2006 Share Posted February 26, 2006 Magnetics are pretty inexpensive and are neat looking (better than tape!)If you do use magnetics, just use a little tape on the leading edge. I drive a pokey little Honda Civic and still managed to blow one untaped one off, I think it was at Thunder Hill... Quote Link to comment Share on other sites More sharing options...
FocusTed Posted February 27, 2006 Share Posted February 27, 2006 Magnetics work very well, it's better to use a single number plate for each side of the car. I also have a little trick for you; If you put the number plates leading edge about 1.5-2 inches from the leading edge of the door, you should be able to get by without using tape. The turbulence from the crack in the door will not allow the wind to catch the leading edge of the number plate. It works very well. Quote Link to comment Share on other sites More sharing options...
Gairloch Posted February 27, 2006 Share Posted February 27, 2006 ^^ Ohhh, good trick! Here's a link to a place that makes magnets and vinyl static cling numbers for a pretty reasonable price. Quote Link to comment Share on other sites More sharing options...
Talon Posted March 10, 2006 Author Share Posted March 10, 2006 I will give that a try... thanks, Ted. Quote Link to comment Share on other sites More sharing options...
mprother Posted March 18, 2006 Share Posted March 18, 2006 What numbers can you use? What happens if you have a duplicate number? Is there a list somewhere? -Mike Quote Link to comment Share on other sites More sharing options...
