Sidney Posted January 13, 2004 Posted January 13, 2004 For Sale: 1983 Chevrolet Z28 Camaro AGS/AS/AI/CMC Racecar Factory Fiberglass hood Factory Aluminum front bumper beam Brake ducts & tubing w/ Stainless steel mesh in openings Wired with battery mount to rear floor Rear control arms w/ Poly bushings Bilstein custom rear shocks Ground Control 1000 lbs front springs New ball joints Largest Trans-Am front sway bar available Hawk Pads, like new Tilton brake proportioning valve Modified rear panhard bar Poly bushings in front A-arms Poly Trans mount bushing (Complete Energy Suspensions kit) Camber plates Strut tower brace IROC wheels 16x7 (2 sets) Good factory radiator Quick ratio 1LE steering box Autopower bolt-in roll cage Window net Autometer gauges Electrical Cut-off switch Fire Extinguisher Very clean, painted gray underbody, engine room, and interior. $1,500 Sidney Franklin Bloomington, IL [email protected] Quote
