wm577 Posted April 26, 2023 Posted April 26, 2023 (edited) 2006 Mustang GT - Location is Morgantown WV. Engine / Drivetrain / Wheels: 5 speed manual MGW Short through shifter V8 4.6L 3v – stock internals (57,000 miles) Kooks stainless headers High flow stainless cats and X pipe 93 octane custom tune with SCT flash tool (tool included with sale) High Flow Engine oil cooler (13x8x2.5) with thermostat. AN 12 fittings Oil pressure and temp sensors. Ford Performance Ring and Pinion Gear Kit; 3.73 Gear Ratio Ford Performance Torsen limited slip Differential AMR Wheels 18x10 (1 set of 4 black with tires, 1 set of 4 silver no tires) Nitto NT555 tires, 275/35/18 Autopower roll bar. Hard wired lap timing transponder 5-point harness has current state inspection Brakes: Ford Performance Mustang GT 14 in. Brake Upgrade Kit M-2300-S (Brembo brakes from 07-09 GT500) Stainless steel braked lines front and rear. Front brake ducts (2.5 inch) Extra Hawk DTC-60 pads for front and rear, and an extra set of front rotors. Suspension: Ford Performance Front Lower Control Arms (arms from 07-09 GT500) Whiteline Sway Bar Kit Adjustable Heavy-Duty Front and Rear MCS TT1 Single Adjustable Dampers with adjustable spring perch (Front and Rear, 18 rebound settings) Currently set to 1.0” drop front and rear. Vorshlag front adjustable Camber Plates Sprint rates = 550 #/in Front / 250 #/in Rear Fluids: Power steering – Amsoil ATFQT Engine Oil – 5-20w mobile 1 full synthetic Transmission - Amsoil ATFQT Brake fluid – MOTUL RBF600 Oil filter – wix no. 57202XP [Asking $14,000] - car is in great shape, zero rust, always kept inside. Can be used as track or daily driver. Never crashed. Edited August 11, 2023 by wm577 removed DAQ system and sold it. Quote
wm577 Posted May 9, 2023 Author Posted May 9, 2023 (edited) lowered price. ? $14,000 Edited June 4, 2023 by wm577 Quote
