bkrantz Posted April 8, 2006 Posted April 8, 2006 After selling the rolling chassis to a shop for a Toyota conversion, I have these spares for sale: New 5 Fram oil filters PH 3985 1 clutch cover 1 wheel bearing (roller) 4 Champion spark plugs RN9YC 4 NKG spark plugs B7ES 3 sets of Performance Friction brake pads (4 pads each) plus 3 more pads 7 Renault factory flywheel bolts master cylinder rebuild kits (2 brake and 1 clutch) timing belt alternator belt 16 open-end lug nuts ITG foam air filter assembly for Weber IDF Used Weber 40 IDF with Rebello intake manifold Rebello cylinder head (low hours) 4 Rebello pistons with recessed heads 2 original spec racer carbs and intake manifolds 8 original Renault pistons 1 set headers with silver Jet-hot coating outside, surface rust inside 1 set headers with slightly mangled exit tube 1 exhaust pipe with supertrap cap 3 Renault cylinder heads starter motor over-flow bottle and cage trans-axle (jumps out of first gear) Make me an offer for any or all. Just remember to factor in shipping from Houston. I also have some blocks, cranks, and other parts that are free for pick-up. Bob K 281-373-4514 [email protected] Quote
