05 cayuse Posted May 17, 2006 Share Posted May 17, 2006 We are just finishing installing a 4 pt. roll bar in my vert, and would like you folk's input on what roll bar padding is best? The tube diameter is 1 3/4". I see a number of different styles and quality on Ebay. Thanks. Quote Link to comment Share on other sites More sharing options...
Gairloch Posted May 17, 2006 Share Posted May 17, 2006 You might want to be a little careful of anything that's not clearly labeled FIA approved. safedrives.com is a good source for most safety equipment. Quote Link to comment Share on other sites More sharing options...
05 cayuse Posted May 19, 2006 Author Share Posted May 19, 2006 Thanks! I'll check them out. Quote Link to comment Share on other sites More sharing options...
sonny Posted May 22, 2006 Share Posted May 22, 2006 We are just finishing installing a 4 pt. roll bar in my vert, and would like you folk's input on what roll bar padding is best? The tube diameter is 1 3/4". I see a number of different styles and quality on Ebay. Thanks. What convertible? I went with SFi padding from Summit Racing. I also put a vinyl cover over it to make it look OEM. Surf around my home page under the Miata/Aftermarket section to see how I did mine. Quote Link to comment Share on other sites More sharing options...
05 cayuse Posted May 22, 2006 Author Share Posted May 22, 2006 thanks for the tip, I'll check it out. My vert is an 05 Mustang. Quote Link to comment Share on other sites More sharing options...
granracing Posted May 22, 2006 Share Posted May 22, 2006 There's the softer "squishy" stuff, then there's a harder version. Get the harder version. Quote Link to comment Share on other sites More sharing options...
