Levy Racing Posted May 22, 2006 Share Posted May 22, 2006 Ford 302 Billit crank, new in the box- $750 351 siamese bore dry sump block w/ forged 351 crank, needs 1 sleeve- $800 157 tooth aluminum flywheel- $200 Aviad Mustang road race oil pan for 351- new- $350 18lb quartermaster multi-disc clutch and flywheel assy 157 tooth, 26 spline, slightly used- it was $1150 new- $700 Quartermaster high clearance 302/351 steel bell housing w/hydraulic throw out bearing- new- $350 Big tube headers for fox using TFS R heads, 1 set for 302 and 1 set for 351- $200 each Call 480-446-8442 Quote Link to comment Share on other sites More sharing options...
