runningmole Posted June 6, 2006 Share Posted June 6, 2006 I have a 93 Mustang (hatchback) and would like to put the battery in the rear. Will any relocation kit pass Tech? Does it need any extra brackets to hold it down? Will any kill switch work? I was going to put it behind the license plate, and just remove the rear plate at the track. Thanks Quote Link to comment Share on other sites More sharing options...
DonBar Posted June 11, 2006 Share Posted June 11, 2006 I have a 93 Mustang (hatchback) and would like to put the battery in the rear. Will any relocation kit pass Tech? Does it need any extra brackets to hold it down? Will any kill switch work? I was going to put it behind the license plate, and just remove the rear plate at the track. Thanks As long as the positive terminal is covered and the battery is restrained (and not with duct tape) you'll be OK. Put it in a marine battery box with a strap to secure the lid and that'll take care of the terminal covering requirement. It also makes for a cleaner install. Quote Link to comment Share on other sites More sharing options...
