rayk Posted June 24, 2006 Share Posted June 24, 2006 New to HPDE and want to upgrade my seat and harness setup. Have a 2004 Mustang GT and the seats and belt setup are marginal. What seat and harness would you recommend? Thanks, Ray Quote Link to comment Share on other sites More sharing options...
firehawkclone Posted June 25, 2006 Share Posted June 25, 2006 What is the intended use of the car? I.E. track only! If you put a "race" seat & belts in, you SHOULD put atleast a rollbar in!And it would be better to have a expert install all of it! GO ALL THE WAY OR LEAVE IT ALL STOCK! Now for what seat is the best.... everybody likes different stuff. So go over to a local shop if you can and try some on I run a Sparco Evo2, Gforce 6pt, and a Autopower race 4pt Hope this helps, John Quote Link to comment Share on other sites More sharing options...
GAC Posted June 26, 2006 Share Posted June 26, 2006 Yes, as John says, all this equipment is designed to work hand in hand. You don't want to mix and match as that can actually make the car more dangerous. If you decide to go "full boat", I recommend the Recaro Pole Position. I have two of 'em in my car. Quote Link to comment Share on other sites More sharing options...
jfranci3 Posted June 26, 2006 Share Posted June 26, 2006 What's wrong with the stock seats other than it's impossible to stick both sides of your behind in the seat at the same time What's the car usage? The reason people are asking is that some seats recline, others don't. You don't want to run a harness unless you've got a rollbar and racing seat installed. If you don't have those and plan on using the car on the street often, you'll probably want to with a reclining seat with a nice cushy bottom used along with the factory 3pt belt. If you plan on a dedicated car, you're going to want a proper racing seat. Quote Link to comment Share on other sites More sharing options...
