EurosportRally Posted September 15, 2006 Share Posted September 15, 2006 I purchased this dash display for a project that never took place and have no use for it now. It is brand new, in the box with all accessories. Paid $795 for it, willing to let it go from $700 including the shipping. Here is the description from the company site: 250-DS-UDXRP: This model comes standard with all the basic instrumentation needed to operate your vehicle. Standard features include engine rpm, water temperature, oil pressure and battery voltage. You can optionally add oil temperature and fuel pressure by simply purchasing the required sender. Need more sensors? The VNet port will allow you to add up to 32 additional channels for the ultimate in expandability. The UDXRP model can record up to 10 minutes of data which you can play back later on the LCD display. You can also upgrade this model to download recorded data to our DataLink PC software for complete analysis. ($795.00) Approx. dimensions: 4.00" tall, 10.20" wide, 2.125" thick. (0.825" bezel + 1.30" back housing) Total clearance required behind mounting surface: 2.0" Thanks, Andrew andrewhadjiminas AT gmail DOT com Quote Link to comment Share on other sites More sharing options...
