sn8byte Posted March 4, 2004 Share Posted March 4, 2004 NEW BABY ON THE WAY FORCES SALE 1972 Datsun 240z built to ITS Class Spec with 24' open trailer for sale $7200 (located in Burbank, CA). Email for photos and with any questions MOTOR & DRIVETRAIN · 240Z engine std bore cylinders honed within spec, new rings, rod bearings, & main bearings. (built for ITS) · Rebuilt 240Z 4-speed “b-box” with new 280Z clutch and pressure plate (zero miles on clutch & P.Plate · Rebuilt E31 cylinder head (w/ new Cam) · Rebuilt carbs w/ new fuel lines · Electronic ignition · Large Radiator, new hoses, new H2O pump, overflow tank, & Electric fan (on switch) · New Transmission and Diff mount · Welded exhaust system BRAKES · All new calipers, pads, & rotors · All new drum brakes & shoes · New steel-braided brake lines · New Master cylinder · Disk brake air ducting SUSPENSION & TIRES · Ground Control Coil-Overs w/ Camber kit · Tokico 5-way adj shocks · New tie-rod ends & Ball joints · Front sway bar (rear not installed) · New Tension Rod Bushings · New Steering Bushings · 14x6 Aluminum Race Wheels & Tires (Toyo) SAFETY · 6 point Autopower bolt-in roll cage · 15Gal Fuel Cell with fume enclosure w switched electric fuel pump · 2 Kill-Switches installed (Dash & Cowl) · Mounted Fire Extinguisher · Wrap around Racing Seat w/ Schroth quick release harness · Window net · Fresh air plumbing TRAILER · 25' Industrial strength dual axel · Includes 2 wheel straps & Class 3 ball · Has a 6’ x 6’ open box for tools, jack, tires, ect... · CA registration good through 2004 EXTRAS/SPARES · 240Z engine block, Crankshaft, & Head · Fiberglass rear spoiler (not installed) · Rear sway bar (not installed) · Bunch of other stuff - too much to list · 14x7 Aluminum Wheels with street tires (For transport to and from events) ~~~~~~~~~~~ 1972 Datsun 240z built to ITS Class Spec with 24' open trailer for sale $7200. Email for photos and with any questions Quote Link to comment Share on other sites More sharing options...
