rppngears91 Posted November 20, 2006 Share Posted November 20, 2006 Hey guys Iam going to be a driving a Mustang this upcoming season. I have a 91 Mustang with simple bolt ons here and there (heads, headers, ignition, and 24 lbs ejectors). It does have 100,000 miles on the block though. I was wondering if it would be a bad idea to drive it on track, without giving it a rebuild? Thanks guys cya Quote Link to comment Share on other sites More sharing options...
Frank Corkran Posted November 20, 2006 Share Posted November 20, 2006 100k miles is just getting broken in if it was well maintained. I'm right now pulling the original motor out of my '88 track Mustang with 200k miles. The last 40k over the last 4 years were mostly either on track or driving to/from the track. Despite being 1960's technology (and built on 1960's machinery), the 302 longblock is amazingly reliable. As long as it still has good oil pressure and compression, just continue to change the oil often and have at it. Quote Link to comment Share on other sites More sharing options...
dwc Posted November 22, 2006 Share Posted November 22, 2006 I've got a '95 Cobra that saw its first HPDE at 110,000 miles. I've done 8 HPDE's now and it still runs fine. It's a dedicated track car so I run it hard, but I try and shift about 5500 RPMs. Quote Link to comment Share on other sites More sharing options...
rppngears91 Posted November 23, 2006 Author Share Posted November 23, 2006 very nice, thanks a lot guys!! Yes it has always been very well maintained, i'd like to do another compression test on it tho just for a check up. I did only two cylinder when i first got my compression tester and I think they were both around 120-140 i cant remember, does that sound ok? Its should b fine tho. thanks again! Quote Link to comment Share on other sites More sharing options...
fast_frank_d Posted November 25, 2006 Share Posted November 25, 2006 I've got a stock 1990 with 120k+ and 4 weekends. It still runs fine, except about 5-10psi lower on oil pressure after the first weekend. I think the root cause was that I was losing oil pressure in the turns. I got a Canton road race oil pan, and it's been holding steady since. If your car handles good, I'd get the oil pan to protect the long block. FD Quote Link to comment Share on other sites More sharing options...
Keith Posted November 26, 2006 Share Posted November 26, 2006 My road race car still has the stock speedo and odometer and it has +110,000 miles on the original motor. These old small blocks live forever. Have fun. Quote Link to comment Share on other sites More sharing options...
hound dog Posted November 27, 2006 Share Posted November 27, 2006 Have been driving an '88 Trans Am WS6 with 187,xxx miles on it and it does just fine. Will probably have to overhaul in a couple of years though since the 305 is down on power a bit Quote Link to comment Share on other sites More sharing options...
rppngears91 Posted November 27, 2006 Author Share Posted November 27, 2006 I was pretty sure i didnt have to worry about the engine, the transmission on the other hand makes some pretty nasty sounds at high rpms, and my syncros are just about done, i think the moron who had the car before never heard of heel toe. thanks guys c ya Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted November 28, 2006 Share Posted November 28, 2006 I'd worry about the brakes on that car personally.... just keep an eye on your fluid levels and the drivetrain should be good to go Quote Link to comment Share on other sites More sharing options...
rppngears91 Posted November 30, 2006 Author Share Posted November 30, 2006 I'd worry about the brakes on that car personally.... just keep an eye on your fluid levels and the drivetrain should be good to go kbrew, what do u mean exactly? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted November 30, 2006 Share Posted November 30, 2006 are you on the stock brakes on that car? at a trackday, you really put some heat through them, and Foxes don't exactly have the best brakes ever. PLEASE spend some cash on the best race pads you can find for the car and put some brake fluid in that will handle tracking (I'd recommend Motul 600 fluid, and ask around the Mustang guys what pad seems to work best). brake fade sucks Quote Link to comment Share on other sites More sharing options...
rppngears91 Posted November 30, 2006 Author Share Posted November 30, 2006 oooo i gotcha, yea ive swap those crappy drum brakes out for sum rear discs and im using hawk blue pads. hopefully that will be okay, it worked good last year? any suggestion to make it better besides pads n fluid by any chance? Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted November 30, 2006 Share Posted November 30, 2006 that should do for stock-ish levels of power I'd think. If you're not getting close to fade don't worry about it yet I haven't tracked my Fox, 300+whp, stock brakes, 3.5" wide fronts.... yeah... heheh Quote Link to comment Share on other sites More sharing options...
mcmmotorsports Posted November 30, 2006 Share Posted November 30, 2006 I did an HPDE at Rockingham in my '04 GT, rear pads had PLENTY of meat on them when I got to the track. After just one session, pads were gone and were chewin' into the rear rotors. Luckily, there was an Autozone nearby. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 1, 2006 Share Posted December 1, 2006 and I learned in a similar way to bring spares with me Quote Link to comment Share on other sites More sharing options...
rppngears91 Posted December 1, 2006 Author Share Posted December 1, 2006 I did an HPDE at Rockingham in my '04 GT, rear pads had PLENTY of meat on them when I got to the track. After just one session, pads were gone and were chewin' into the rear rotors. Luckily, there was an Autozone nearby. were they racing pads or just average Pepboys pads?? just wondering thanks for the advice Quote Link to comment Share on other sites More sharing options...
runningmole Posted December 1, 2006 Share Posted December 1, 2006 I have a spare set of rotors and some Hawk Black pads for the track. Street pads on the rear, and they are holding up. Cobra brake setup. Quote Link to comment Share on other sites More sharing options...
Gray Ghost Posted December 21, 2006 Share Posted December 21, 2006 I have a '93 Celica GT that I run once in awhile in HPDE 3 that has over 150K miles. I first focused on what would keep the car reliable and safe, e.g. replace the timing belt, complete tune-up, performance brake pads (EBC "Yellow") with stock rotors, all synthetic fluids (to include Super Blue ATE brake fluid), etc. and it runs great shifting at 5700 RPMs with no issues (knock on wood...) I think with a Ford Mustang - regular oil changes and quality oil filter, e.g, Baldwin, AMSoil and WIX, run synthetic in your differential and transmission (if allowed by the manufacturer). Quote Link to comment Share on other sites More sharing options...
