Markus Posted December 12, 2006 Share Posted December 12, 2006 Just wondering since I don't see this listed under Aero or Free stuff.... For convertibles, a hardtop can be an advantage. Should this be charged any points under "Aero"? Or is it an open/free item since it's also somewhat safety related? Just curious since I don't see it in either place. Thanks! - Mark Quote Link to comment Share on other sites More sharing options...
slink Posted December 13, 2006 Share Posted December 13, 2006 look under weight reduction #19. if you drop your top and bolt on a hard top no points , you just added weight. but if you remove the convertible top and bolt on the hard top 2 points. Quote Link to comment Share on other sites More sharing options...
jrok Posted December 13, 2006 Share Posted December 13, 2006 Hey Slink, What is your new class in all this? Quote Link to comment Share on other sites More sharing options...
slink Posted December 13, 2006 Share Posted December 13, 2006 looks like tta jerry. where will you be Quote Link to comment Share on other sites More sharing options...
Markus Posted December 13, 2006 Author Share Posted December 13, 2006 look under weight reduction #19 Oops I skipped this, I was assuming most people would use the alternate weight reduction method. Which basically means there is no aero penalty for a hardtop. Thanks! - Mark Quote Link to comment Share on other sites More sharing options...
Members Shawn M. Posted December 13, 2006 Members Share Posted December 13, 2006 (edited) look under weight reduction #19 Oops I skipped this, I was assuming most people would use the alternate weight reduction method. Which basically means there is no aero penalty for a hardtop. Thanks! - Mark What? Not run with your shinney metal hat? The aliens will get you if you dont! Edited December 18, 2006 by Guest Quote Link to comment Share on other sites More sharing options...
jrok Posted December 13, 2006 Share Posted December 13, 2006 looks like tta jerry. where will you be 2005 Porsche Boxster S, manual transmission Weight: 2987 (per porsche.com) Horsepower: 280 OEM Tires: 235/40-18, 265/40-18 ---------------------- 2006 Base class: TTC* +7 = * (from base class) +7 = Hoosier R6 road race slicks +1 = Rear tires 30mm over OEM width +1 = Cat-back exhaust +2 = Non-OEM coil springs +1 = Non-OEM brake pads +0 = Non-OEM air filter -- 19 = Final Class: TTC + 19 points ---------------------- 2007 Base class: TTC* + 7 = * (from base class) +10 = Hoosier R6 road race slicks +13 = Rear tires 50mm over "Base Class Tire Size" + 1 = Cat-back exhaust + 2 = Non-OEM coil springs + 0 = Non-OEM brake pads + 0 = Non-OEM air filter --- 33 = Final Class: TTB + 13 points Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 18, 2006 Share Posted December 18, 2006 damn, you got shafted Jerry the way staggered sizes are treated really screws us Mid-Engine guys Quote Link to comment Share on other sites More sharing options...
jrok Posted December 19, 2006 Share Posted December 19, 2006 damn, you got shafted Jerry the way staggered sizes are treated really screws us Mid-Engine guys ...and then some. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 19, 2006 Share Posted December 19, 2006 TTF tire size just changed from 205 to 215, I just got 3 points back as-is sorry man, singing a different tune now best of luck next year, hope to make the April MO event as well as Nat'ls Quote Link to comment Share on other sites More sharing options...
