jon dawes Posted September 20, 2007 Author Share Posted September 20, 2007 (edited) If exiting oak tree you lost power, coasting to the hot pit for the south paddock oops, hypo should have read 'after passing the South Paddock'. And please note jon, that your car does not NEED a cold air kit or any filtration for that matter in order to run. You DO however need to have the mass air sensor attached. If it were to come loose allowing the motor to draw in unmetered air, that would cause trouble. not sure how you're car's set up, but i'm assuming it's very close if not the same. the sensor is inside the tube. if the tube pops off, by necessity the sensor is no longer functioning and the throttle body sucks however much air is there. my '07 died on me almost immediately going over Key Bridge last week when the CAI popped off [K&N design flaw if you ask me]. hence the source of this hypo. . . As far as the comment above about KNOWING what is wrong with your car and that you knew before hand.....are you kidding? I never take my car out onto the track KNOWING something is wrong. I would just assume SKIP a session or an entire DAY for that matter, then risk an on track failure. HEY BUDDY: IT'S MY DAMN HYPO! if you don't like it, tough! [this is what they tell you in law school if you don't like the hypo] and you might be misreading the hypo: you obviously don't know something is wrong when you go out. but if something happens that you know/suspect has happened before [loose wire, clogged flux capacitor, bad turn signal valve, worn muffler bearing, etc.], there may be a chance to fix it quickly if you have the worker's permission or are in a protected spot. But again, the point is DON'T GET OUT OF THE CAR unless you/car's on fire. . . unless some highly unlikely circumstance exists that it is SAFE and you have PERMISSION to do so [see supra]. I think I'll just stay in the car if something known or unknown happens to avoid any question as to my intelligence/safety. ps: i also acknowledge/appreciate that this is a forum and if something happens out there, the CCRs and Officials have the final say. . . i'm not planning on saying 'but you said on the forum that ____________' Edited September 20, 2007 by Guest Quote Link to comment Share on other sites More sharing options...
NorrFam Posted September 20, 2007 Share Posted September 20, 2007 Dear Group These two actually are friends. That's why they give each other such a hard time. Quote Link to comment Share on other sites More sharing options...
jon dawes Posted September 20, 2007 Author Share Posted September 20, 2007 of course, what Paul said! i hope that Colin would consider me a friend! just don't mess with the friggin hypo Quote Link to comment Share on other sites More sharing options...
Renntag Posted September 21, 2007 Share Posted September 21, 2007 Jon you may ask what ever questions you wish regardless of how retarded they may seem. Quote Link to comment Share on other sites More sharing options...
jon dawes Posted September 24, 2007 Author Share Posted September 24, 2007 hey, i'm full of them! Quote Link to comment Share on other sites More sharing options...
