BrianZ Posted November 3, 2004 Share Posted November 3, 2004 (edited) So who's comming? I am amd I'm bringing 3 HPDE'ers.. Edited November 10, 2004 by Guest Quote Link to comment Share on other sites More sharing options...
civicrr Posted November 3, 2004 Share Posted November 3, 2004 future HC racers I hope you know I will be there. engine is tuned now with a bit more power too. Quote Link to comment Share on other sites More sharing options...
slammed_93_hatch Posted November 3, 2004 Share Posted November 3, 2004 ill be there, with your distributor. but i will be without my civic. There is no way in hella i can get it together beefor then. Quote Link to comment Share on other sites More sharing options...
mikeski38 Posted November 3, 2004 Share Posted November 3, 2004 The sol and the suby are for sure, my dad is still trying to find a third gear shift fork for the teg. Quote Link to comment Share on other sites More sharing options...
BrianZ Posted November 3, 2004 Author Share Posted November 3, 2004 The sol and the suby are for sure, my dad is still trying to find a third gear shift fork for the teg. what about your favorite place? or the honda junkyard in the sac area ? Quote Link to comment Share on other sites More sharing options...
civicrr Posted November 3, 2004 Share Posted November 3, 2004 actually, the problem is that they don't make that part anymore, there isn't anymore stock & there isn't a superceded part. I thought that he had found a tranny? Quote Link to comment Share on other sites More sharing options...
Ron Carroll Posted November 3, 2004 Share Posted November 3, 2004 I will be there, and we will have Donna's car done so she will be there also. I talked to steve yesterday and the part that is bad should be able to be repaired. Quote Link to comment Share on other sites More sharing options...
zuperdave Posted November 3, 2004 Share Posted November 3, 2004 I'll be there in the HPDE3/4 group on Saturday only . Jimmy, bring your helmet and enough $$$ for a passenger wristband and -- if you don't mind going slow in the straights -- I'll give you a ride Quote Link to comment Share on other sites More sharing options...
Andrie Posted November 3, 2004 Share Posted November 3, 2004 Any H1 guys coming? Or should I head to Buttonwillow Quote Link to comment Share on other sites More sharing options...
mikeski38 Posted November 3, 2004 Share Posted November 3, 2004 I have a better idea andrie...BUILD AN H4 CAR! Quote Link to comment Share on other sites More sharing options...
slock Posted November 3, 2004 Share Posted November 3, 2004 It's fixed I'll be there so everyone just moved down one place in the finish. Quote Link to comment Share on other sites More sharing options...
Andrie Posted November 3, 2004 Share Posted November 3, 2004 It's fixed I'll be there so everyone just moved down one place in the finish. Steve, that's the smack talk of the month!! Quote Link to comment Share on other sites More sharing options...
Andrie Posted November 3, 2004 Share Posted November 3, 2004 I have a better idea andrie...BUILD AN H4 CAR! Shoot, we have not even get the H1 car back and running again. Still undecided on the axle as I don't want this to happen again. It was a brand new axle, only on the second race. How bout letting me drive for 1 day I might be able to help with suspension setup. Quote Link to comment Share on other sites More sharing options...
mikeski38 Posted November 3, 2004 Share Posted November 3, 2004 Hmmmm, let me know if you really want to drive 1 day. I'm in financial distress so if you want to run with me next weekend, I would consider it. Also this way I could get you hooked on H4. You could build a car for cheap to run with us in nor cal and run your H1 down south. You could have one ready for next season no problem. I think I have brent convinced to switch. Quote Link to comment Share on other sites More sharing options...
Andrie Posted November 3, 2004 Share Posted November 3, 2004 Mike, what's your email. Or shoot me an email at andrie"at"gmail"dot"com Brent just had bad luck with his engine. He had been running stock engine and still has problem. Maybe the problem is not the engine, but the wiring or something else. Got to trace the problem to fix it, not change the engine to H4 Brent, don't do it!!!! Quote Link to comment Share on other sites More sharing options...
mikeski38 Posted November 3, 2004 Share Posted November 3, 2004 My email is [email protected]. Brent, H4 H4 H4 H4!!!!!! Don't let Andrie temped you. H1 is not stronger, just more seductive, once you start down the H1 path, forever will it dominate your destiny. The big problem with H1 for the budget minded racer, is that a running car won't make you competative. The rules are written so a few extra $ can go into an H1 car and make it fast. $ doesn't make H4 cars fast, just expencive. Any H4 car that runs, can be competative. Quote Link to comment Share on other sites More sharing options...
slammed_93_hatch Posted November 4, 2004 Share Posted November 4, 2004 Im serously thinking aobut buying an 92-95 SOHC VTEC and changing everything over to "si" spec's. its hard as FUCK to find a short block. ONly thing is Im feeling pretty strong about rebuilding ANY motor i buy after this last one let loose on me. Then again, i dunno DOHC VTEC is WAY to much fun, to just toss out the window Quote Link to comment Share on other sites More sharing options...
BrianZ Posted November 4, 2004 Author Share Posted November 4, 2004 I'm mixed here... I would like to see you in H4, but Andrie needs someone else on the track too.. just get it running and come out and play. Quote Link to comment Share on other sites More sharing options...
mikeski38 Posted November 4, 2004 Share Posted November 4, 2004 After a couple of laps you will get used to the extra HP of an H1 anyway. Go H4. Quote Link to comment Share on other sites More sharing options...
grocery runner Posted November 4, 2004 Share Posted November 4, 2004 It's fixed I'll be there so everyone just moved down one place in the finish. Dream on buddy!! You boys WILL BE SPANKED!! I think all you will see is "passed by a chic" sticker in a blur!! Quote Link to comment Share on other sites More sharing options...
ek_brandon Posted November 4, 2004 Share Posted November 4, 2004 ZING! Quote Link to comment Share on other sites More sharing options...
zuperdave Posted November 4, 2004 Share Posted November 4, 2004 It's fixed I'll be there so everyone just moved down one place in the finish. Dream on buddy!! You boys WILL BE SPANKED!! I think all you will see is "passed by a chic" sticker in a blur!! Do you think she meant "chic" or do you think she really meant "chick" and just does not remember any of her French lessons from high school -- or high society ? Quote Link to comment Share on other sites More sharing options...
mikeski38 Posted November 4, 2004 Share Posted November 4, 2004 Hey donna! Nice screen name. Glad to hear your car is up and running. I visited my new place of work the other day and saw the ol' grocery runner, it looked pretty good. There is a possibility that Andrie will be driving my del sol on sunday. Make sure he has fun so he will dump those H1 money pits and come race an affordable car. Quote Link to comment Share on other sites More sharing options...
Ron Carroll Posted November 4, 2004 Share Posted November 4, 2004 Dream on buddy!! You boys WILL BE SPANKED!! I think all you will see is "passed by a chic" sticker in a blur!! Yea, it will be a blur as I blow past you. Quote Link to comment Share on other sites More sharing options...
grocery runner Posted November 4, 2004 Share Posted November 4, 2004 It's fixed I'll be there so everyone just moved down one place in the finish. Dream on buddy!! You boys WILL BE SPANKED!! I think all you will see is "passed by a chic" sticker in a blur!! Do you think she meant "chic" or do you think she really meant "chick" and just does not remember any of her French lessons from high school -- or high society ? Chic:adj. cleverly stylish:smart,currently fashionable!! You know, I've tried to find a drivers nomex suit in a dress and driving shoes in high heel pumps, but I can't find them!!! Quote Link to comment Share on other sites More sharing options...
