brkntrxn Posted March 27, 2012 Share Posted March 27, 2012 Waiting to see more people try the 245s though, might be "too far", might not be. Or could very well be course-dependent. track-dependent has my vote if I had an unlimited budget I'd have a different pts sheet, tire/wheel, trans, shock, sway bar, and rear gear combo for every track If I had a budget like that, I would never turn a wrench or tow the trailer. Arrive and drive via Grand Am or something. Quote Link to comment Share on other sites More sharing options...
brkntrxn Posted March 27, 2012 Share Posted March 27, 2012 Got it. Appreciate the help. I know the car won't be totally prepped, but at the same time I need it to be a little civilized still since I won't be trailering it to events. If you are driving to events, then you need to build your car around a Hoosier R6 at the softest. More likely a Nitto NT01. I would not drive Hoosier A6s back and forth to an event. The lack of tread would not bother me, the softness of the tires and how quickly they would wear out or get a puncture would be my concern. Unless you are going to put a hitch on the car and trailer a spare set. Quote Link to comment Share on other sites More sharing options...
docwyte Posted March 27, 2012 Author Share Posted March 27, 2012 I have a tire trailer, so my plan is to put a hitch on the car and pull the trailer with a set of wheels/race tires on em that I'll swap at the track. Quote Link to comment Share on other sites More sharing options...
Cobra4B Posted March 27, 2012 Share Posted March 27, 2012 track-dependent has my vote We'll see how they work somewhere other than VIR for the PTA Royal Rumble at RA in June Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted March 27, 2012 Share Posted March 27, 2012 If I had a budget like that, I would never turn a wrench or tow the trailer. Arrive and drive via Grand Am or something. unlimited NASA grassroots budget = 1 race, back marker, field filler Grand Am budget Quote Link to comment Share on other sites More sharing options...
Cobra4B Posted March 27, 2012 Share Posted March 27, 2012 If I had a budget like that, I would never turn a wrench or tow the trailer. Arrive and drive via Grand Am or something. unlimited NASA grassroots budget = 1 race, back marker, field filler Grand Am budget I just threw in 5 bucks for the company PowerBall lotto thing.. once I win I will dominate all of NASA. Or maybe I'll team up with an indian tribe and start a cash loan company. I hear my great great grandmother was Cherokee. Quote Link to comment Share on other sites More sharing options...
jason Posted March 27, 2012 Share Posted March 27, 2012 If I had a budget like that, I would never turn a wrench or tow the trailer. Arrive and drive via Grand Am or something. unlimited NASA grassroots budget = 1 race, back marker, field filler Grand Am budget Or 1/3 of a back-marker GTC effort to be slower than PTA cars. Quote Link to comment Share on other sites More sharing options...
Varkwso Posted March 28, 2012 Share Posted March 28, 2012 Or you can run min weight, the mods from the point free list and 295 A Hoosier tires on a stock C5Z. Min weight and free mods are the key. Jeff, Why are you making me do this? Are you testing us? You know we revere anything and everything you normally say. You cannot run 295 Hoosier A6s on a C5Z06 and stay in TTA. The A6 is +13 and the C5Z is +7, so that puts you at +20 mod points and straight to the bottom of TTS. -Kevin I was testing you.... Took you long enough... Quote Link to comment Share on other sites More sharing options...
Varkwso Posted March 28, 2012 Share Posted March 28, 2012 If I had a budget like that, I would never turn a wrench or tow the trailer. Arrive and drive via Grand Am or something. unlimited NASA grassroots budget = 1 race, back marker, field filler Grand Am budget And the drivers are probably better in NASA on average. Quote Link to comment Share on other sites More sharing options...
brkntrxn Posted March 28, 2012 Share Posted March 28, 2012 Now you three are changing the definition of "unlimited". Back to the OP: Sounds like you have a solid plan. A's, sways, and pads are all you need to be in the top half of a normal PTA field. In the SE, it will take more than that due to the Mafia influence. Quote Link to comment Share on other sites More sharing options...
beerkat Posted March 28, 2012 Share Posted March 28, 2012 I have not read where you want to tow a small tire trailer. If you are planning on driving to the track on the same tires then you need to run the Nitto R2s. Running DOT Hoosier on the street will wear them out pretty fast. Several of us have run the R2s and like them. Not Hoosiers but a good tire. Quote Link to comment Share on other sites More sharing options...
toomchpwr Posted April 5, 2012 Share Posted April 5, 2012 i'm psyched to run TTA with NE region in my z06. my car is down on power (340 SAE) but i'll make it work for now. 2004 shocks, T1 bars, 275 A6's, brey krause bar, sparco's, DRM oil cooler, hawk DTC 70/60's, tow hooks, dual catch cans. Putting on honker cold air intake soon to help with the HP. Car has relatively new c6 z06 clutch with associated heavy flywheel so i'm not in a rush to put in a lightweight flywheel but that would also help with some HP. If I go for a new motor (refresh this one; maybe next year), then I will put in aluminum FW. Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted April 5, 2012 Share Posted April 5, 2012 Car has relatively new c6 z06 clutch with associated heavy flywheel so i'm not in a rush to put in a lightweight flywheel but that would also help with some HP. The LS7 clutch is a very, very heavy assembly. If it was in my car and I was doing TT, that would be the first thing I'd toss! sounds like you have a good proven combo, you should do well Quote Link to comment Share on other sites More sharing options...
Bnjmn Posted April 5, 2012 Share Posted April 5, 2012 See you at NJMP. Stop by when you get a moment (black TTA C5 #99). Quote Link to comment Share on other sites More sharing options...
toomchpwr Posted April 5, 2012 Share Posted April 5, 2012 will do Ben! I'm #11, electron blue Z Quote Link to comment Share on other sites More sharing options...
