laze1 Posted April 30, 2012 Share Posted April 30, 2012 So, my shop can't get the C-clips back into my 2007 350z Base model diff after installing the wavetrac....anybody else having this problem? Wavetrac sez my stub axles are not compatible...WTF BTW: A Nissan dealer is doing the work.... Quote Link to comment Share on other sites More sharing options...
Pelle51 Posted April 30, 2012 Share Posted April 30, 2012 I had a similar issue when I changed the rear diff on our 2008. I had to order a new stub axle for the right side. The two stub axles for the wave trac need to be the same length, the right side one on my stock unit was longer and was bottoming out before the c-clip could engage. Call Paul at Nissan Motorsports he was able to supply me with the correct part. Quote Link to comment Share on other sites More sharing options...
laze1 Posted April 30, 2012 Author Share Posted April 30, 2012 (edited) I have an "Open Diff" from a 2007 base model (not a VLSD)...and is "supposed" to have the correct stub axles per Wavetrac and Nissan...so we are looking at ordering some new stubb axles for a "Open Diff" and see if that helps Thnx for your feedback....how do you like the Wavetrac now? Edited May 1, 2012 by Guest Quote Link to comment Share on other sites More sharing options...
Fixxxercask Posted May 1, 2012 Share Posted May 1, 2012 I emailed Paul St. Clair at Nissan inquiring about needing different stub axles or needing anything else with the Wavetrac and he never emailed me back. Does anyone else have issues contacting these people. I emailed him last week about the prices on parts. No reply. I have emailed several of those people with no response. What gives? I need to order some parts. Why have an email address if you can't respond to emails. I understand they probably get a lot of emails, but a week is more than enough time to respond. Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 1, 2012 Author Share Posted May 1, 2012 yes, those Nissan folks are "hard to get" for sure... BTW: Info from the Wavetrac website about requirements: http://www.autotech.com/mm5/merchant.mvc?Screen=PROD&Store_Code=stock&Product_Code=44-309-181WK&wavetrac=1 Wavetrac® LIMITED SLIP DIFFERENTIAL NISSAN 350Z M/T 2003-2008 NISSAN 370Z M/T 2009-2010 In USA and Canada, contact: Nissan Motorsports Nissan North America tel: (888) 833-3225 email: [email protected] VEHICLES WITH OEM VISCOUS LSD MUST REPLACE RH AXLE FLANGE WITH NISSAN #38220-AR000 (1 req) FLANGE TO INSTALL WAVETRAC. Wavetrac® diffs are state-of-the-art helical gear differentials designed, developed, and manufactured in the USA by Autotech Driveline. The Wavetrac® Differential is the only torque biasing differential on the market with patent-pending technology that mitigates wheelspin when an unloaded wheel condition arises. During zero axle load conditions, the Wavetrac cam device acts to create internal load, maintaining drive on the gripping wheel instead of acting like an open diff (and going nowhere!). Super strong 9310 alloy steel gears are enclosed in case-hardened steel bodies, held together with ARP® fasteners. All Wavetrac® differentials include a transferable, Limited Lifetime Warranty. Quote Link to comment Share on other sites More sharing options...
scotts300 Posted May 1, 2012 Share Posted May 1, 2012 yes, those Nissan folks are "hard to get" for sure... BTW: Info from the Wavetrac website about requirements: http://www.autotech.com/mm5/merchant.mvc?Screen=PROD&Store_Code=stock&Product_Code=44-309-181WK&wavetrac=1 Wavetrac® LIMITED SLIP DIFFERENTIAL NISSAN 350Z M/T 2003-2008 NISSAN 370Z M/T 2009-2010 In USA and Canada, contact: Nissan Motorsports Nissan North America tel: (888) 833-3225 email: [email protected] VEHICLES WITH OEM VISCOUS LSD MUST REPLACE RH AXLE FLANGE WITH NISSAN #38220-AR000 (1 req) FLANGE TO INSTALL WAVETRAC. Wavetrac® diffs are state-of-the-art helical gear differentials designed, developed, and manufactured in the USA by Autotech Driveline. The Wavetrac® Differential is the only torque biasing differential on the market with patent-pending technology that mitigates wheelspin when an unloaded wheel condition arises. During zero axle load conditions, the Wavetrac cam device acts to create internal load, maintaining drive on the gripping wheel instead of acting like an open diff (and going nowhere!). Super strong 9310 alloy steel gears are enclosed in case-hardened steel bodies, held together with ARP® fasteners. All Wavetrac® differentials include a transferable, Limited Lifetime Warranty. I experienced a lot of unloaded wheel spin after eight, 20-minute lapping sessions. Will change fluid and pray that helps. Quote Link to comment Share on other sites More sharing options...
Fixxxercask Posted May 2, 2012 Share Posted May 2, 2012 What fluid were you using and what do you plan on changing it with? Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 2, 2012 Author Share Posted May 2, 2012 this is what I plan to run... Redline Diff fluid WITHOUT friction Modifiers: 75W140 NS GL-5 Gear Oil comments welcome... What fluid were you using and what do you plan on changing it with? Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 2, 2012 Author Share Posted May 2, 2012 Good stub axle pix from Wavetrac Pics of my 2007 base model open diffs stub axles Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 2, 2012 Author Share Posted May 2, 2012 and the answer is: purchase "new" but "old style" stub axles... $%^&*()_*(&^%&*()_(*&^%&*() not happy with Nissan and Wavetrac... Quote Link to comment Share on other sites More sharing options...
Fixxxercask Posted May 3, 2012 Share Posted May 3, 2012 That sucks man! That's kind of what I was getting at before about Nissan. I have emailed Paul a couple time asking about the Wavetrac. I asked if there was a different model for the base model Z's and for the Z's with VLSD. I know when I orded my Quaiffe, I had to specify. There is none of that for the Wavetrac. My frustration is no one from Nissan replied about any of this and it clearly can be an issue for many people. It would be nice to know this ahead of time. I do know now, but unfortunately at your expense. I have an 04 base model with a Quaiffe in it, so I think I am good. Right? Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 3, 2012 Author Share Posted May 3, 2012 Nopper...not for Spec Z. Your diff must have an OEM or the Spec part. So your Quaiffe is not legal for Spec Z. I have an 04 base model with a Quaiffe in it, so I think I am good. Right? Quote Link to comment Share on other sites More sharing options...
scotts300 Posted May 3, 2012 Share Posted May 3, 2012 That sucks man! That's kind of what I was getting at before about Nissan. I have emailed Paul a couple time asking about the Wavetrac. I asked if there was a different model for the base model Z's and for the Z's with VLSD. I know when I orded my Quaiffe, I had to specify. There is none of that for the Wavetrac. My frustration is no one from Nissan replied about any of this and it clearly can be an issue for many people. It would be nice to know this ahead of time. I do know now, but unfortunately at your expense. I have an 04 base model with a Quaiffe in it, so I think I am good. Right? Time to order Wavetrac, or go back to OEM! Quote Link to comment Share on other sites More sharing options...
Fixxxercask Posted May 4, 2012 Share Posted May 4, 2012 Sorry. I should have been more clear. I know I cannot use the Quaiffe diff. I meant am I good in terms of...do I have the correct stub axles to fit the Wavertrac? Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 4, 2012 Author Share Posted May 4, 2012 If you have this stub axle you are good to go Quote Link to comment Share on other sites More sharing options...
Fixxxercask Posted May 4, 2012 Share Posted May 4, 2012 Another question that may have been answereed...sorry. Is this the situation where you need that axle just one the one side or did you need both sides? Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 4, 2012 Author Share Posted May 4, 2012 Well, you need 2x short stub axles. (with flat ends) for the Wavetrac install Most VLSD diff have 1x long stub and 1x short, you need 2x shorts...so one new short stub must be installed Most Open diffs have 2x shorty stub axles (with flat ends) so no change is required to install the Wavetrac Unfortunatel...mine is a 2007 open diff that had 2x equal length short shaft stub axles but with "mushroom" ends that Nissan and Wavetrac don't appear to know exist. I my case I had to order 2x new short stub axles. (with flat ends) Simple...right??? Another question that may have been answereed...sorry. Is this the situation where you need that axle just one the one side or did you need both sides? Quote Link to comment Share on other sites More sharing options...
paulwalshnissan Posted May 4, 2012 Share Posted May 4, 2012 Well, you need 2x short stub axles. (with flat ends) for the Wavetrac install Most VLSD diff have 1x long stub and 1x short, you need 2x shorts...so one new short stub must be installed Most Open diffs have 2x shorty stub axles (with flat ends) so no change is required to install the Wavetrac Unfortunatel...mine is a 2007 open diff that had 2x equal length short shaft stub axles but with "mushroom" ends that Nissan and Wavetrac don't appear to know exist. I my case I had to order 2x new short stub axles. (with flat ends) Simple...right??? Another question that may have been answereed...sorry. Is this the situation where you need that axle just one the one side or did you need both sides? yeah, sounds real simple now.....LOL Quote Link to comment Share on other sites More sharing options...
velocitymotorsports Posted May 6, 2012 Share Posted May 6, 2012 Just a note on the diff oil. The redline lightweight shockproof (alien blood) will take the abuse of racing conditions and keep on going. If anyone needs a good diff builder one of the best is Stan at GBOX in Colorado. Thanks. Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 6, 2012 Author Share Posted May 6, 2012 Wave trac sez DO NOT USE Redline Shockproof oil...or any oil with any friction modifiers Quote Link to comment Share on other sites More sharing options...
Fixxxercask Posted May 7, 2012 Share Posted May 7, 2012 Thanks for the clarification laze. I may be in the clear. My car was a open diff and now has a Quaiffe in it. I don't recall having to pay for different axles when I had it installed. I am going to get the WT diff soon and sell my Quaiffe. I am going to do the install this time. Hope I can get some decent money for it. Thanks again! Quote Link to comment Share on other sites More sharing options...
scotts300 Posted May 7, 2012 Share Posted May 7, 2012 Wave trac sez DO NOT USE Redline Shockproof oil...or any oil with any friction modifiers So what ARE you going to use? Quote Link to comment Share on other sites More sharing options...
laze1 Posted May 30, 2012 Author Share Posted May 30, 2012 I had planned to use Redline 75w140 NS fluid...that doesn't have any friction modifiers... http://www.redlineoil.com/product.aspx?pid=39&pcid=4 140 NS GL-5 Gear Oil Contains extreme pressure additives like our 75W140 GL-5 oil, but lacks friction modifiers to balance slipperiness Popular for historic and vintage transmissions, like Mid-1930s to early-1950s synchro-equipped gearboxes in cars and trucks Helps with noisy or rough shifting in troubled A-833 Dodge/Plymouth 4-speed transmissions from 1964 to 1969 Option for noisy transmissions when mixed with 75W90NS or MT-90 to bring viscosity level up Also used in clutch-type limited slip differentials in racing for maximum lock up-some users add Limited Slip Friction Modifier in small doses to customize slippage Recommended for API GL-5, GL-6, MT-1, MIL-L-2105E, and SAE J2360 Then today, a Spec Z racer told me he talked with Wavetrac and they are now recommending Motul 75x140 Comp http://performanceoilstore.com/proddetail.asp?prod=823511 Motul GEAR COMP 75w140 1L 1 liter container (enter 12 for case discount) Specially formulated for gear boxes and limited slip differentials for race cars. Motul exclusive technology approved for extreme endurance racing conditions: 24 Hrs Lemans, Japanese GT Championship, Hewland and X-Trac gearboxes. Nissan Non-Nismo diff. Price: $29.95 Quote Link to comment Share on other sites More sharing options...
laze1 Posted July 4, 2012 Author Share Posted July 4, 2012 Installing diff cooler to help the Wavetrac make it thru the season...a real PIA..but worth it I suppose... Quote Link to comment Share on other sites More sharing options...
C.Plavan Posted July 9, 2012 Share Posted July 9, 2012 Having run a "Real" LSD in my Porsches, just by adding a Transcooler with minimum -10 fittings you should see a huge difference. I was getting almost to 300 degrees before, but once I flip a switch, the trans temp will lower quickly to almost mirror the engine oil temp. You will see a difference, do not get discouraged. That is also using the small single fan Setrab Fan pack unit. You could get the "Double" pack if you want to increase the fluid amount. http://www.hrpworld.com/index.cfm?form_prod_id=3394&action=product Quote Link to comment Share on other sites More sharing options...
