Red Tornado Posted June 14, 2012 Share Posted June 14, 2012 Ok hoosier now has a battle Will be curious how many heat cycles Hoosiers last vs new toys. This will be critical as Hoosiers quicker and bigger vs toyo by a good amount. Toyos cheaper but slower but may last way longer.... Love having to choose Quote Link to comment Share on other sites More sharing options...
robbodleimages Posted June 14, 2012 Share Posted June 14, 2012 you are in love with the slick world since WC it seems. Quote Link to comment Share on other sites More sharing options...
D Algozine Posted June 14, 2012 Share Posted June 14, 2012 Isn't AI a Toyo RA1 spec tire? Quote Link to comment Share on other sites More sharing options...
Micks 41 Posted June 14, 2012 Share Posted June 14, 2012 Isn't AI a Toyo RA1 spec tire? Until Toyo stops writing checks to NASA or they stop producing the RA-1 (again). Quote Link to comment Share on other sites More sharing options...
Adam Ginsberg Posted June 14, 2012 Share Posted June 14, 2012 Isn't AI a Toyo RA1 spec tire? AI is not eligible for the Toyo RS1 contingency. AIX, PTx, STx, etc. Quote Link to comment Share on other sites More sharing options...
Red Tornado Posted June 15, 2012 Author Share Posted June 15, 2012 Come on and run AIX...the water is warm...jump right in By the way tire compound is exact same as RA1 just internals and shoulder different. So life should be close to the same. Quote Link to comment Share on other sites More sharing options...
rpoz27 Posted June 15, 2012 Share Posted June 15, 2012 Come on and run AIX...the water is warm...jump right in By the way tire compound is exact same as RA1 just internals and shoulder different. So life should be close to the same. Actually, if you read Toyo's website, it says same compound as R888...no thanks. RS1's are more expensive than 18" RA1's and there are no 17's. Rains? Quote Link to comment Share on other sites More sharing options...
philstireservice Posted June 24, 2012 Share Posted June 24, 2012 Come on and run AIX...the water is warm...jump right in By the way tire compound is exact same as RA1 just internals and shoulder different. So life should be close to the same. Actually, if you read Toyo's website, it says same compound as R888...no thanks. RS1's are more expensive than 18" RA1's and there are no 17's. Rains? Actually the RA-1, R888 and RS1 are all the same rubber compound (GG)......... Quote Link to comment Share on other sites More sharing options...
stevepoe Posted June 24, 2012 Share Posted June 24, 2012 Actually the RA-1, R888 and RS1 are all the same rubber compound (GG)......... no wonder the new ra1's are only good for about 10-12 sessions before they go to crap. Quote Link to comment Share on other sites More sharing options...
robbodleimages Posted June 24, 2012 Share Posted June 24, 2012 i thought the long durability was the reason to use the ra1 as a spec tire. 10 cycles is all? Quote Link to comment Share on other sites More sharing options...
wstukas Posted June 24, 2012 Share Posted June 24, 2012 10-12 cycles? Nobody told me. The last set I took off my car had 45 heat cycles... Quote Link to comment Share on other sites More sharing options...
philstireservice Posted June 25, 2012 Share Posted June 25, 2012 Isn't AI a Toyo RA1 spec tire? Until Toyo stops writing checks to NASA or they stop producing the RA-1 (again). Next year you might be on a molded tire from Toyo ( like the R6). Quote Link to comment Share on other sites More sharing options...
robbodleimages Posted June 25, 2012 Share Posted June 25, 2012 another spec tire change? you're kidding, right? Quote Link to comment Share on other sites More sharing options...
stevepoe Posted June 25, 2012 Share Posted June 25, 2012 10-12 cycles? Nobody told me. The last set I took off my car had 45 heat cycles yes , I agree with the old Toyo Tires. I ran a set for 12 sessions and they where junk. Put a fresh set on and picked up 1.7 seconds a lap. Come on up north with those 45 heat cycled tires..... You won't be running a fresh/recent dated set that long Quote Link to comment Share on other sites More sharing options...
Red Tornado Posted June 25, 2012 Author Share Posted June 25, 2012 The tires continue to impress me. 10 heat cycles and only lost about 2 seconds from sticker. Yes that still a drop but most of my others tires last 4-6 heat cycles to cord The RS1 still looks fairly On my old car RA1s lasted 16-24 heat cycles with no drop in times, in fact they got better as a comparison. Of course that was 2008 ish tires so I think they chgd compound for shorter life since then Either way if they have dot and slick next year they seem like they last double competition. Never compared vs BFG yet Quote Link to comment Share on other sites More sharing options...
stevepoe Posted June 26, 2012 Share Posted June 26, 2012 10 heat cycles and only lost about 2 seconds from sticker 2 seconds is a ton Chris. so it sounds like they are good for what ? 8 or so heat cycles ? heard that new bfg is a heck of a tire. Yes back in the day we could pound the ra till it corded but this new one is nothing like the old one that is for sure. Quote Link to comment Share on other sites More sharing options...
Members Ed M. Posted June 26, 2012 Members Share Posted June 26, 2012 (start oriental music palying in background...) "Look at the BFG's Grasshoppers - either the R1 or R1S..." (stop music). http://www.jacksonmotorsportsgroup.com/ Of course, this only applies to the open tire classes - AIX in our case... Ed Quote Link to comment Share on other sites More sharing options...
Red Tornado Posted June 26, 2012 Author Share Posted June 26, 2012 I have not driven any tire in over 3 years that hasn't dropped off 1 second at LEast from its sticker heat cycle. That last one was old compound toyo If you want to win need sticker or fresh shave plain and simple In world challenge we qualify and race on same tire and it drops a solid second. Quote Link to comment Share on other sites More sharing options...
Silverback Posted July 24, 2012 Share Posted July 24, 2012 If you want to win need sticker or fresh shave plain and simple In world challenge we qualify and race on same tire and it drops a solid second. Excuse the clueless and off topic question... but do you still "heat cycle" the tires before they're raced? Quote Link to comment Share on other sites More sharing options...
robbodleimages Posted July 24, 2012 Share Posted July 24, 2012 heat cycling lenthens the time a DOT racing tire can provide competitive lap times. the process of the heat cycle knocks the new or the fastest times out of the tires in the process. so....if budget is not an issue, you race sticker tires and throw them a way. if have a limited number of tires you sacrifice the speed for wear life. i use a qualifying session to heat cycle a set of tires. when we heat cycle we run laps 70-75%, 80-85% and then one hot lap. regardless of how that lap goes you come in. its a real gamble. then you put that set of tires away for 24 hours to a week. Quote Link to comment Share on other sites More sharing options...
philstireservice Posted July 24, 2012 Share Posted July 24, 2012 heat cycling lenthens the time a DOT racing tire can provide competitive lap times. the process of the heat cycle knocks the new or the fastest times out of the tires in the process. so....if budget is not an issue, you race sticker tires and throw them a way. if have a limited number of tires you sacrifice the speed for wear life. i use a qualifying session to heat cycle a set of tires. when we heat cycle we run laps 70-75%, 80-85% and then one hot lap. regardless of how that lap goes you come in. its a real gamble. then you put that set of tires away for 24 hours to a week. hmmmmm?.....heat cycling is designed to do two things. It may make your tires last longer and it may make the tire faster sooner. Being that the fastest lap and or car doesn't always win the race, throwing away your fastest lap times, as Rob suggests ( and heat cycling doesn't do), I would take consistency and longevity over the possibility of one less fast lap. I highlight MAY because car setup and driver style make a big difference in whether a tire lasts or performs as designed. Quote Link to comment Share on other sites More sharing options...
Silverback Posted July 26, 2012 Share Posted July 26, 2012 Thanks for the info guys. Phil - is the 315/30R18 R1S actually available? If yes, how does pricing compare to Hoosiers? Quote Link to comment Share on other sites More sharing options...
Red Tornado Posted July 26, 2012 Author Share Posted July 26, 2012 Be aware mine definitely are true size as Phil stated. Don't be expecting huge Hoosiers. Quote Link to comment Share on other sites More sharing options...
philstireservice Posted July 27, 2012 Share Posted July 27, 2012 Thanks for the info guys. Phil - is the 315/30R18 R1S actually available? If yes, how does pricing compare to Hoosiers? There is nothing yet that equates to a 315/30R18 exactly in the RS1. The 285/650R18 is the same overall diameter/height, but it is not quite as wide. But remember we are talking a slick here compared to DOT tire. The construction is different which in turn gives the tire different characteristics. The stiffness will compensate sometimes for the narrower section width. Quote Link to comment Share on other sites More sharing options...
Cmy70go Posted September 7, 2012 Share Posted September 7, 2012 Better use up your RA1's from 2012. I see another fiasco. From the toyo website... Sep 6, 2012 8:00am New Proxes RR DOT Competition Tire Provides Ultimate Dry Traction CYPRESS, CALIFORNIA -- Toyo Tire U.S.A. Corp. has released the new Toyo Proxes RR, a DOT competition tire designed for dry tracks. Its symmetric design uses two circumferential grooves molded to a 4/32nd tread depth with additional wear inspection holes on the void areas. This race-ready design eliminates the need for tire shaving and provides ultimate traction with superior cornering force. The racing tread compound of the Proxes RR delivers maximum dry performance and improved lap times for the serious racers competing in NASA or SCCA competition. It is also great for track days and Time Attack competition. With the advanced compound and rayon carcass of the Proxes RR drivers can expect predictable handling and consistent lap times throughout its life. The reinforced sidewall of the Proxes RR delivers excellent steering response. A sidewall marking area is also a part of the design, allowing racers to easily label their tires. “The new Toyo Proxes RR is the perfect tire for road racers that are serious about winning,” said Stan Chen, manager of events and motorsports, Toyo Tire U.S.A. Corp. “It also complements our already popular portfolio of race-proven tires including the new Proxes RS1 and legendary Proxes RA1.” The new Proxes RR has a 40 C A treadwear rating and is available in three popular competition sizes: 205/50ZR15, 225/50ZR15 and P275/35ZR18 87LL. It is recommended for competition events only. To learn more about the new Proxes RR and the full line of Proxes competition tires, log onto www.toyotires.com. Quote Link to comment Share on other sites More sharing options...
