Sidney Posted January 6, 2012 Share Posted January 6, 2012 NOW STILL NOT SURE ON THE FRONT BRAKES 1LE, HOME MADE 1LE WITH C4 CALIPERS, LS1 OR C5 ??? TIME WILL TELL Don't mess with 1LE calipers. Pad and caliper cost are the same for the LS stuff and the LS's are much better. With that said...the Wilwood upgrade is less expensive in the long run due to much cheaper pad cost. Kent Owens or TJ can explain this option in more detail. Sidney Quote Link to comment Share on other sites More sharing options...
Interceptor Posted April 16, 2012 Share Posted April 16, 2012 What's the best bet for a 9-bolt rear? Currently has the cast-iron calipers and small discs. Quote Link to comment Share on other sites More sharing options...
nape1548534725 Posted April 16, 2012 Share Posted April 16, 2012 What's the best bet for a 9-bolt rear? Currently has the cast-iron calipers and small discs. Find a 10-bolt with PBR calipers. The service parts just aren't around for a 9-bolt and neither are performance parts. Quote Link to comment Share on other sites More sharing options...
